Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
Is there a way via scripting to read UDP messages? Basically I'd want to cut to a specific input on receiving a UDP message and then switch to another on receiving another UDP message.
The reason for this is the system generating the commands can't do HTTP or TCP, just UDP. However, we can format those UDP messages as we like.
I'd been searching and can't find any information on this concept.
Thanks in advance.
Fritz Golman iHeartMedia
Joined: 2/23/2023(UTC) Posts: 89  Thanks: 30 times Was thanked: 20 time(s) in 6 post(s)
There is nothing built into vMix that supports this. However, a custom application could be written that proxies incoming UDP messages and then sends HTTP (or raw TCP) messages on to vMix.
Feel free to send me a private message, as I am available to hire if you would like this program written!
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: ryxyz  There is nothing built into vMix that supports this. Tried "System.Net.Sockets.UdpClient" instead of the usual Imports System.Net.Sockets?
Originally Posted by: ryxyz  There is nothing built into vMix that supports this. a working try  vMixUDP.jpg (59kb) downloaded 49 time(s).
Impressive!
This may just do the trick.
Now to set some actions!
Thanks!
Fritz
OK this has been working great!
One further question, I set up an action that is trapped to shut down the script. All is well BUT it needs to close the UDP connection so it's free for the next time it's run (otherwise port stays open and throws an error). No matter what I've tried I've not been able to get the UDP connection to close. Would anyone have the script commands to do this?
Thanks!
Never mind, figured it out.
receivingudpclient.close()
Hey, Adding to this thread. Firstly, the UDP receiver script has been working great. It's been allowing interface between an automation system and vMix. Using it on several, high profile network programs broadcast in the USA. NOW, a slightly different need has arisen for use within this script. Although keeping the UDP receiver running, I'd also like to send out on a UDP command another UDP command to a different IP/Port when the script gets a specific input. Anyone have any experience with this? We would open UDP transmit port at beginning of script. Then when specific UDP command intercepted, send a string out on that port. Anyone? I don't know the specifics of VB Script enough to make this work. I've been lucky in that I've been able to cobble together the rest and it's been solid. Thanks for any input on this! UPDATE A search revealed a script snip using TCP (which will be fine) that can work with modifications: https://forums.vmix.com/...g-for-Dummies#post114636Fritz Golman iHeartMedia
Adding to this to see if anyone has had any experience with scripting UDP transmission.
I've been using TCP to send without issue BUT now have a requirement to SEND UDP, not just receive (as I've done already). Not getting anywhere trying to adapt TCP sending to the UDP environment.
Anyone have some code they might share to demonstrate this?
Thanks!
Fritz Golman RadioDNA
UPDATE: Solved!
Dim udpclient As New System.Net.Sockets.udpClient("127.0.0.1", 62300)
Dim comCommand as String = "TEST" Dim data As [Byte]() data = System.Text.Encoding.ASCII.GetBytes(comCommand & Environment.NewLine)
udpClient.Send(data, data.Length)
