Mairaj
#1 Posted : Wednesday, January 10, 2024 2:54:56 AM(UTC)
Mairaj
Pakistan
I want to initiate 2 SDI out from vMix, is that possible to initiate it through single vMix instance? or do I have to run 2 instances of vMix?
Further please note that both SDIs are different streams.
nikosman88
#2 Posted : Wednesday, January 10, 2024 3:07:21 AM(UTC)
nikosman88
Greece
Hi. You can do it from one vmix instance but
1.You need vmix version 4k/pro/max
2. You need hw that will have 2 sdi out
Mairaj
#3 Posted : Wednesday, January 10, 2024 3:13:48 AM(UTC)
Mairaj
Pakistan
Thanks for your reply.
Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option.
nikosman88
#4 Posted : Wednesday, January 10, 2024 3:45:01 AM(UTC)
nikosman88
Greece
You can assign output1 to sdi1 external out and output2 to sdi2 external2 out. And in output2 you will assign the input you need to send. If you have 2 completelly different streams-->2 productions same time from 1 pc then yes you need another vmix instance in which you have to assign in external the sdi2 from your bmd cardto 2nd vmix instance
Mairaj
#5 Posted : Wednesday, January 10, 2024 5:21:04 AM(UTC)
Mairaj
Pakistan
means I should use total 2 instances, I will try to do it with a single instance (to save system resources) and will revert back.
anyways, thanks a lot for suggestion it means a lot!
nikosman88
#6 Posted : Wednesday, January 10, 2024 9:20:06 AM(UTC)
nikosman88
Greece
Yes it can also be done with some workaround (for example mini mixes and audio buses) from one instance
Mairaj
#7 Posted : Wednesday, January 10, 2024 9:38:46 AM(UTC)
Mairaj
Pakistan
Yeah right, I think audio buses will do the trick with single instance, will give it a try and revert back!
Mairaj
#8 Posted : Saturday, January 13, 2024 12:22:04 AM(UTC)
Mairaj
Pakistan
achieve it with 2 instances, and both instances with different audio buses, works like a charm, the reason for two audio buses is both my streams are totally different. Thanks a lot!
Guest (4)
