2 SDI out from single or two instances of vMix
I want to initiate 2 SDI out from vMix, is that possible to initiate it through single vMix instance? or do I have to run 2 instances of vMix?
Further please note that both SDIs are different streams.
Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out
Originally Posted by: nikosman88  Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out Thanks for your reply. Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option.
Originally Posted by: Mairaj  Originally Posted by: nikosman88  Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out Thanks for your reply. Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option. You can assign output1 to sdi1 external out and output2 to sdi2 external2 out. And in output2 you will assign the input you need to send. If you have 2 completelly different streams-->2 productions same time from 1 pc then yes you need another vmix instance in which you have to assign in external the sdi2 from your bmd cardto 2nd vmix instance
Originally Posted by: nikosman88  Originally Posted by: Mairaj  Originally Posted by: nikosman88  Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out Thanks for your reply. Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option. You can assign output1 to sdi1 external out and output2 to sdi2 external2 out. And in output2 you will assign the input you need to send. If you have 2 completelly different streams-->2 productions same time from 1 pc then yes you need another vmix instance in which you have to assign in external the sdi2 from your bmd cardto 2nd vmix instance means I should use total 2 instances, I will try to do it with a single instance (to save system resources) and will revert back. anyways, thanks a lot for suggestion it means a lot!
Originally Posted by: Mairaj  Originally Posted by: nikosman88  Originally Posted by: Mairaj  Originally Posted by: nikosman88  Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out Thanks for your reply. Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option. You can assign output1 to sdi1 external out and output2 to sdi2 external2 out. And in output2 you will assign the input you need to send. If you have 2 completelly different streams-->2 productions same time from 1 pc then yes you need another vmix instance in which you have to assign in external the sdi2 from your bmd cardto 2nd vmix instance means I should use total 2 instances, I will try to do it with a single instance (to save system resources) and will revert back. anyways, thanks a lot for suggestion it means a lot! Yes it can also be done with some workaround (for example mini mixes and audio buses) from one instance
Originally Posted by: nikosman88  Originally Posted by: Mairaj  Originally Posted by: nikosman88  Originally Posted by: Mairaj  Originally Posted by: nikosman88  Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out Thanks for your reply. Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option. You can assign output1 to sdi1 external out and output2 to sdi2 external2 out. And in output2 you will assign the input you need to send. If you have 2 completelly different streams-->2 productions same time from 1 pc then yes you need another vmix instance in which you have to assign in external the sdi2 from your bmd cardto 2nd vmix instance means I should use total 2 instances, I will try to do it with a single instance (to save system resources) and will revert back. anyways, thanks a lot for suggestion it means a lot! Yes it can also be done with some workaround (for example mini mixes and audio buses) from one instance Yeah right, I think audio buses will do the trick with single instance, will give it a try and revert back!
Originally Posted by: Mairaj  Originally Posted by: nikosman88  Originally Posted by: Mairaj  Originally Posted by: nikosman88  Hi. You can do it from one vmix instance but 1.You need vmix version 4k/pro/max 2. You need hw that will have 2 sdi out Thanks for your reply. Please note that both SDIs are different streams & yes I have blackmaic Duo 2 which have 2 SDIs option. You can assign output1 to sdi1 external out and output2 to sdi2 external2 out. And in output2 you will assign the input you need to send. If you have 2 completelly different streams-->2 productions same time from 1 pc then yes you need another vmix instance in which you have to assign in external the sdi2 from your bmd cardto 2nd vmix instance means I should use total 2 instances, I will try to do it with a single instance (to save system resources) and will revert back. anyways, thanks a lot for suggestion it means a lot! achieve it with 2 instances, and both instances with different audio buses, works like a charm, the reason for two audio buses is both my streams are totally different. Thanks a lot!
