Instant Replay
How To Convert Vmix Replay Inpoint/ OutPoint to Time
How can i convert Vmix replay in or out point to H:i:s is the value in milliseconds? i have tried to divide it with 1000000 but the result is not correct? any idea?
Joined: 12/27/2012(UTC) Posts: 5,512  Location: Belgium Thanks: 316 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: dror  How can i convert Vmix replay in or out point to H:i:s is the value in milliseconds? i have tried to divide it with 1000000 but the result is not correct? any idea? A search function is a cool thing ;-) Google: convert milliseconds to hh mm ss or even better google vmix instant replay timestamp = https://forums.vmix.com/...--or-something-like-that
first thank you for your help but i didnt ask for no reason
i have seen all of the posts about it,
i did convert it but i get a wrong result ,
this is the value = 170400000 in vmix the time is 10:47:23.89 but my result is 23:20:00
Originally Posted by: dror  first thank you for your help but i didnt ask for no reason
this is the value = 170400000 in vmix the time is 10:47:23.89 but my result is 23:20:00 did you see this post too? https://forums.vmix.com/...play-XML-InPoint-To-Timesomething about taking into account start recording time, frame counts etc
Joined: 1/25/2019(UTC) Posts: 329  Thanks: 23 times Was thanked: 82 time(s) in 62 post(s)
i assume you are taking the times from the xml file in the replay folder. if i create a clip that is approx. 1 minute long, then i get the value of 605600000 (outpoint-inpoint), which corresponds to a value of 1:00:56. (mm:ss:ms) Quote:<event> <inPoint>162600000</inPoint> <outPoint>768200000</outPoint> <selectedAngle>0</selectedAngle> <description>Event 1 Minute</description>  oneminute.JPG (10kb) downloaded 1 time(s).The value you specified 170400000 is therefore 00:17:40 the values are in ticks, the smallest available value among the windows time units (approx. 100 nanoseconds) you can convert it like this: Code:'number of ticks
dim ticks As Long = 170400000
'create TimeSpan from ticks
dim timeSpan As TimeSpan = TimeSpan.FromTicks(ticks)
'format TimeSpan as timestring (hh:mm:ss.ms)
dim formattedTime As String = String.Format("{0:D2}:{1:D2}:{2:D2}:{3:D2}",timeSpan.Hours, timeSpan.Minutes, timeSpan.Seconds, timeSpan.Milliseconds)
console.writeline(formattedTime)
to get the time of the in- or outpoint, you have to calculate the tick values from the actual start time of the recording (starttime - inPoint) or (start time - outPoint), in this example 12:08:57.8940669 You can find the starttime at the bottom of the XML file: Quote:<segment> <timestamp>2024-01-07T12:08:57.8940669+01:00</timestamp> the start time can also be converted to ticks: Code:'time as string
dim timestamp As String = "12:08:57.8940669"
'change timestamp to TimeSpan
dim timeSpan As TimeSpan = TimeSpan.Parse(timestamp)
'convert TimeSpan to ticks
dim ticks As Long = timeSpan.Ticks
'result in ticks
console.writeline(ticks)
thank you ! i what language is the code written?
vb net, you can copy the code into a empty script window of vmix, see scripting in help files. you need to have 4K version or higher
Instant Replay
