AndrzejK
#1 Posted : Tuesday, December 26, 2023 8:54:40 AM(UTC)
AndrzejK
Poland
I would be nice to have an oportunity to add image sequence as part of TransitionIn, Page, TransitionOut elements.
I imagine it like:
- placing the sequence of alpha PNG's into layout and setting them like 1. intro 2. page hold or play (loop, ping) 3. outro,
- with checkbox "when switching to outro, play the "hold" part to the end to prevent glitches",
- you still can set duration of whole sequence, but:
- if checkox is checked, the system calculates the possible durations (1x intro + Nx page + 1x outro) and you can select them from list,
- the images should be RAM cached to better playing.
Of course, you could place other elements, especially text, over the image sequence to build complete title or lower thirds set.
#2 Posted : Tuesday, December 26, 2023 9:14:08 AM(UTC)
which is allready possible
AndrzejK
#3 Posted : Tuesday, December 26, 2023 9:19:39 AM(UTC)
AndrzejK
Poland
I didn't know. How? When I select image, I can add only one.
EDIT: I found on YT vMix channel. Just checking.
#4 Posted : Tuesday, December 26, 2023 9:28:36 AM(UTC)
one can add multiple and give each their own "trigger".
AndrzejK
#5 Posted : Tuesday, December 26, 2023 9:39:53 AM(UTC)
AndrzejK
Poland
I checked and i'm not sure.
1. Can I set different sequences for in/continous/out?
2. Can I set the loop to pingpong?
4. Will the duration set automatically to match the looped sections?
AndrzejK
#6 Posted : Tuesday, December 26, 2023 9:41:14 AM(UTC)
AndrzejK
Poland
OK, you replayed while I was writing my questions :)
