Feature Requests
GT Title Designer - image sequence
Joined: 12/26/2023(UTC) Posts: 5  Was thanked: 1 time(s) in 1 post(s)
I would be nice to have an oportunity to add image sequence as part of TransitionIn, Page, TransitionOut elements.
I imagine it like: - placing the sequence of alpha PNG's into layout and setting them like 1. intro 2. page hold or play (loop, ping) 3. outro, - with checkbox "when switching to outro, play the "hold" part to the end to prevent glitches", - you still can set duration of whole sequence, but: - if checkox is checked, the system calculates the possible durations (1x intro + Nx page + 1x outro) and you can select them from list, - the images should be RAM cached to better playing.
Of course, you could place other elements, especially text, over the image sequence to build complete title or lower thirds set.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: AndrzejK  I would be nice to have an oportunity to add image sequence as part of TransitionIn, Page, TransitionOut elements.
which is allready possible
I didn't know. How? When I select image, I can add only one.
EDIT: I found on YT vMix channel. Just checking.
Originally Posted by: AndrzejK  I didn't know. How? When I select image, I can add only one.
EDIT: I found on YT vMix channel. Just checking. one can add multiple and give each their own "trigger".
I checked and i'm not sure.
1. Can I set different sequences for in/continous/out? 2. Can I set the loop to pingpong? 4. Will the duration set automatically to match the looped sections?
OK, you replayed while I was writing my questions :)
Feature Requests
