Feature Requests
Allow Click-n-Drag Re-Ordering in Lists
Joined: 4/3/2020(UTC) Posts: 21  Location: Severn Thanks: 2 times
I would like to see the ability to click and drag items around in a list for the purpose of reordering them.
This past weekend I ran into a situation with a List input which contained about 150 videos. I added two videos to it but needed to reorder both to near the top of the list. I was able to select both items, however, when I attempted to move them - using the arrow buttons, I noticed that only one item moved. I had to manually move each item, using the buttons, one click at a time. This took an extended period of time; fortunately, I was not in the middle of a production.
If implementing this via the UI will prove challenging, perhaps an alternate implementation could be something similar to how we currently edit Titles. If we could export the List input to a text file and then sort/reorder it, and then import it back - it could be a viable solution. Please let me know if I can provide any screen recording of what I'm aiming at, thank you.
Originally Posted by: kismetgerald  If we could export the List input to a text file and then sort/reorder it, and then import it back - it could be a viable solution. You can allready, export to .m3u and rearrange with notepad or alike and do a change (import) on the list imput
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
+1
(I often have the same issue and it would be really handy to just be able to Click-and-Drag within the vMix environment itself instead of workarounds.)
Feature Requests
