Olesk
#1 Posted: : Thursday, December 21, 2023 5:20:50 AM(UTC)
Olesk
Estonia
I'm trying to change vMix headpohones volume via api.
Function 1. is working correctly. (It decreases volume, but if I want to increase volume, it doesn't work.)
  1. 127.0.0.1:8088/api/?Function=SetBusAVolume&Value=-=10
  2. 127.0.0.1:8088/api/?Function=SetBusAVolume&Value=+=10
Function 2. says invalid parameters. Also it doesn't work in companion.
Thanks!
#2 Posted : Thursday, December 21, 2023 6:44:56 AM(UTC)
Try value+=10
Olesk
#3 Posted : Thursday, December 21, 2023 7:46:41 AM(UTC)
Olesk
Estonia
In vMix shortcuts it works as +=10, but with api it doesn't work for any input or bus volume, while at the same time -=10 works every time. value=+10 doesn't seem to work also.
#4 Posted : Thursday, December 21, 2023 9:05:55 AM(UTC)
Value=%2B%3D10
see after search https://forums.vmix.com/....aspx?g=posts&t=2980
Olesk on 12/21/2023(UTC)
