vMIx api function not working
I'm trying to change vMix headpohones volume via api. Function 1. is working correctly. (It decreases volume, but if I want to increase volume, it doesn't work.) - 127.0.0.1:8088/api/?Function=SetBusAVolume&Value=-=10
- 127.0.0.1:8088/api/?Function=SetBusAVolume&Value=+=10
Function 2. says invalid parameters. Also it doesn't work in companion. Thanks!
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
In vMix shortcuts it works as +=10, but with api it doesn't work for any input or bus volume, while at the same time -=10 works every time. value=+10 doesn't seem to work also.
Originally Posted by: Olesk  In vMix shortcuts it works as +=10, but with api it doesn't work for any input or bus volume, while at the same time -=10 works every time. value=+10 doesn't seem to work also. Value=%2B%3D10 see after search https://forums.vmix.com/....aspx?g=posts&t=2980
