furtive
#1 Posted : Sunday, December 3, 2023 8:09:55 AM(UTC)
furtive
Was thanked: 21 time(s) in 9 post(s)
Many of the use cases I have that require a solution like EVS (e.g. a 5v5 esports event where we have 10x player feeds, or 10x player cams) are due to needing a 10 in / 2 out configuration.
I'm just curious what the reason is for this not being available in vMix Replay? A perceived lack of popularity/demand for that? Concerns about user hardware requirements? UI scaling? Something else?
#2 Posted : Monday, December 4, 2023 12:07:55 AM(UTC)
@ furtive
Basically comes down to hardware capabilities and limitations therein...
You can review vMix Instant Replay system requirements here:
https://www.vmix.com/hel.../SystemRequirements.html
furtive
#3 Posted : Monday, December 4, 2023 11:14:14 AM(UTC)
furtive
That was one of my guesses, but as someone with hardware who could handle this, I'd really like to be able to do it. And was hoping devs/product might chime in with their thoughts.
thanks 1 user thanked furtive for this useful post.
Ario on 12/19/2023(UTC)
Ario
#4 Posted : Tuesday, December 19, 2023 10:54:39 PM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
+1
Morki
#5 Posted : Tuesday, April 2, 2024 7:43:30 PM(UTC)
Morki
Germany
Not sure if this works for you, but whenever I needed to record more outputs than possible, I ran vMix in 4k resolution and created a multiview on an output for 4x 1080p or 9x 720p matrix... You can also add one or more of the 4 outputs as a replay source, or you create a 2x2 matrix view externally (i.e. using a DMON Quad) and take that as another camera input.
You will then need to do some scripting, resizing and cropping for the replays to create a good workflow, but it should be possible.
I know it is not ideal, but if you really need the functionality that might be an option.
Another solution would be to add a second PC just for the additional replay cameras, send the cameras via NDI, and operate everything in sync using companion, macros etc.
thanks 1 user thanked Morki for this useful post.
Ario on 3/12/2025(UTC)
