vMix shuts down and restarts especially when changing presets
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
vMix shuts down and restarts especially when changing presets, after an update....I was scratching my head trying all sorts of troubleshooting ideas, just by chance to check to see which GPU vMix was using...it was using default windows, and not the nvidia GPU....I tried to find a way to get vMix to use the nVidia GPU, but had to do a search , which showed me what to do....so, fellow users, if you ever have this issue of vMix not using the the correct GPU, just open the nVidia control panel, and add vMix to the list of programs to use nVidia.......well, that fixed my issue, maybe it may fix yours as well
Luis70.
Originally Posted by: Luis70  vMix shuts down and restarts especially when changing presets, after an update....I was scratching my head trying all sorts of troubleshooting ideas, just by chance to check to see which GPU vMix was using...it was using default windows, and not the nvidia GPU....I tried to find a way to get vMix to use the nVidia GPU, but had to do a search , which showed me what to do....so, fellow users, if you ever have this issue of vMix not using the the correct GPU, just open the nVidia control panel, and add vMix to the list of programs to use nVidia.......well, that fixed my issue, maybe it may fix yours as well
Luis70. like this ? https://www.vmix.com/kno...n-nvidia-optimus-laptops
