davidcl
#1 Posted : Wednesday, December 6, 2023 1:16:11 AM(UTC)
davidcl
Gabon
hi all
please i dotn find the probleme about my configuration
srt4.jpg (38kb) downloaded 7 time(s). srt3.JPG (33kb) downloaded 7 time(s). srt2.JPG (53kb) downloaded 7 time(s). srt1.JPG (67kb) downloaded 7 time(s).
Please help me
Where is the probleme?
#2 Posted : Wednesday, December 6, 2023 2:34:45 AM(UTC)
Originally Posted by: davidcl Go to Quoted Post
hi all
Please help me
What is your problem?
Whaat is Laryx ?
davidcl
#3 Posted : Wednesday, December 6, 2023 2:44:24 AM(UTC)
davidcl
Gabon
I want to use an Mobile applciation
so Larix Application but if you have another solution applciation no problem
https://softvelum.com/larix/
#4 Posted : Wednesday, December 6, 2023 3:00:44 AM(UTC)
Oh Larix Broadcaster to send SRT video to vMix
davidcl
#5 Posted : Wednesday, December 6, 2023 3:09:31 AM(UTC)
davidcl
Gabon
ye si see that
in local working no problem i send and receive signal from larix to Vmix.
but not on Mobile its for that i send my config IP.
sincerely
#6 Posted : Wednesday, December 6, 2023 3:13:19 AM(UTC)
ye si see that
sincerely
did yu set the larix connection to your public IP ? ( https://www.myip.com/)
did you open up that port to your local IP (vMix machine) on your modem
Have you double checked the video's second part ?
davidcl
#7 Posted : Wednesday, December 6, 2023 3:28:42 AM(UTC)
davidcl
Gabon
i put all the capture of my configuration
i think i was good (but im not very good in network for that ) but i think its ok?
all captures of my config is in my first message
my vmix is in listener the port 5000
#8 Posted : Wednesday, December 6, 2023 3:39:16 AM(UTC)
ye si see that
sincerely
You are using some app from 2016 to mess with your IP ?
davidcl
#9 Posted : Wednesday, December 6, 2023 3:43:41 AM(UTC)
davidcl
Gabon
no its the first time i try to do that.
#10 Posted : Wednesday, December 6, 2023 3:45:08 AM(UTC)
Its pretty easy really (just like in the video )
as mentioned before check you public Ip here ( https://www.myip.com/)
use that in your larix settings (Caller) and port 5000
make sure you have port 5000 open on your Local IP (on your modem)
Set vMix as llistener on port 5000
Make sure the Latency setting is high enough for mobile data use
davidcl
#11 Posted : Wednesday, December 6, 2023 4:03:04 AM(UTC)
davidcl
Gabon
i have on the larix always
Cont connect to server.. retrying.... in loop
all parameters i think are good?
lestra
#12 Posted : Tuesday, April 2, 2024 2:30:05 PM(UTC)
lestra
Saint Kitts And Nevis
Set format to H264
mavik
#13 Posted : Saturday, November 30, 2024 7:19:19 AM(UTC)
mavik
try a
telnet [your public IP] 5000
from a computer in public internet. If you get a response you know the traffic can pass through. If not I guess you need to research NAT/PAT topic. Your device that connect your home with the ISP must forward traffic on port 5000 it receives to your computer. I guess that part is missing in your setup and can be tested with the above command.
I can provide a test connection for your larix so you know if the mobile part works or not.
