SRT
SRT/LARYX ...
Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi all please i dotn find the probleme about my configuration  srt4.jpg (38kb) downloaded 7 time(s). srt3.JPG (33kb) downloaded 7 time(s). srt2.JPG (53kb) downloaded 7 time(s). srt1.JPG (67kb) downloaded 7 time(s).Please help me Where is the probleme?
Originally Posted by: davidcl  hi all please i dotn find the probleme about my configuration
Please help me Where is the probleme? What is your problem? Whaat is Laryx ?
ye si see that in local working no problem i send and receive signal from larix to Vmix.
but not on Mobile its for that i send my config IP. sincerely
Originally Posted by: davidcl  ye si see that in local working no problem i send and receive signal from larix to Vmix.
but not on Mobile its for that i send my config IP. sincerely did yu set the larix connection to your public IP ? ( https://www.myip.com/)did you open up that port to your local IP (vMix machine) on your modem Have you double checked the video's second part ?
i put all the capture of my configuration i think i was good (but im not very good in network for that ) but i think its ok? all captures of my config is in my first message my vmix is in listener the port 5000 ....
but not on Mobile its for that i send my config IP. sincerely You are using some app from 2016 to mess with your IP ?
no its the first time i try to do that.
Its pretty easy really (just like in the video ) as mentioned before check you public Ip here ( https://www.myip.com/)use that in your larix settings (Caller) and port 5000 make sure you have port 5000 open on your Local IP (on your modem) Set vMix as llistener on port 5000 Make sure the Latency setting is high enough for mobile data use
i have on the larix always Cont connect to server.. retrying.... in loop all parameters i think are good?
Joined: 12/16/2019(UTC) Posts: 87  Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
try a telnet [your public IP] 5000 from a computer in public internet. If you get a response you know the traffic can pass through. If not I guess you need to research NAT/PAT topic. Your device that connect your home with the ISP must forward traffic on port 5000 it receives to your computer. I guess that part is missing in your setup and can be tested with the above command. I can provide a test connection for your larix so you know if the mobile part works or not.
SRT
SRT/LARYX ...
