GT
Gt Title not updating
Hi, I have some titles I created and are linked to an Excel spreadsheet to change, names, colors, and images, it works great most of the time but from time to time the Title doesn't updates anymore, I reload the input in vMix and my title goes back to the Original data of the title. When I check the title editor I can see that the Data is OK, the Datasource is working, but even if the title editor has the correct data the graphic title is not refreshing. I try reloading the input, and changing some data in Excel and nothing works, then, suddenly after a couple of minutes, it works again without me doing anything. Has it ever happened to you?
Joined: 7/23/2013(UTC) Posts: 133  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
I recently ran likely in the same issue. I sent a bug report to vMix support and they instructed to capture a video with the phone of the problem when it occurs. Based on the diagnostics data I sent directly from vMix settings they pointed out some CPU overload conditions. However, it's hard to see the connection with random GT title problem and CPU overload.
Did you check whether the correct data is visible through XML API? In my case XML API showed the correct updated title contents, and also with title editor, but actual graphics were "frozen".
Hello. I have same issue with bibleshow.
I have issue when using bibleshow with xml output in vmix with a full screen title as input. When using lower thirds, it work correctly.
it only works for the first scriptures, any scripture after that is not corresponding, its scattered. What can I do or what am i doing wrongly.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
it only works for the first scriptures, any scripture after that is not corresponding, its scattered. What can I do or what am i doing wrongly. is the XML updating ? is the dataconnection to the title correct ?
Yes. The XML updated and dataconnection is correct. I can correctly view data correct with lower third but not with title full-screen
Originally Posted by: Armel14  Yes. The XML updated and dataconnection is correct. I can correctly view data correct with lower third but not with title full-screen Why not show ( provide us) the titles , what do you mean by full screen title (all titles are basically fulll screen , even lower thirds kind) , what do you mean by scatered ?
What I call fullscreen is in the output in this screenshot.  Screenshot_6.jpg (368kb) downloaded 4 time(s).
Originally Posted by: Armel14  What I call fullscreen is in the output in this screenshot.
Why not show ( provide us) the titles . or at least show is the textblock names etc from both titles What versin of the software ?
Version bêta 27.0.0.52 I had the same issue with 26.0.0.37
I have a laptop hp pavilion Intel core i5 11th Gen Ram 16go Ssd 512Go
Originally Posted by: Armel14  Version bêta 27.0.0.52 I had the same issue with 26.0.0.37
I have a laptop hp pavilion Intel core i5 11th Gen Ram 16go Ssd 512Go i am asking for the titles used (at best provide the to us to check), the dataconnection seetings ( screenshot) and the bibleshow version FYI works just fine here (when "show" is active)
 Screenshot_7.jpg (99kb) downloaded 2 time(s). verset plein ecran.gtzip (500kb) downloaded 1 time(s).BibleShow 5.4 version
Originally Posted by: Armel14   verset plein ecran.gtzip (500kb) downloaded 1 time(s).BibleShow 5.4 version Of coursse you didn't show the title settings for datasource connectionIt works just fine  Screenshot 2023-12-02 183206.jpg (131kb) downloaded 2 time(s).Is the "Show" button activated ? this will update the XML file when choosing another verse if so, same applies when using the NDI option!
 Screenshot 2023-12-02 183458.jpg (394kb) downloaded 2 time(s).Can i uninstall this BibleShow app now?
Yes, it works perfectly now. Thanks
Originally Posted by: Armel14  Yes, it works perfectly now. Thanks Care to say what was actually wrong ?
I use show button like in this video ?si=KVJKsli_ARvLgW0m
Originally Posted by: Armel14  I use show button like in this video DUH
GT
