neural
#1 Posted : Thursday, November 30, 2023 2:06:58 AM(UTC)
neural
Italy
Is this configuration ok for a Vmix PC with PRO license for a workstation for 8 camera replays?
Intel Core i9-13900KS processore 36 MB Cache intelligente TRAY
Asus PRO WS W790E-SAGE SE Intel W790 LGA 4677 EEB
Corsair Dominator CMT64GX5M4B6600C32 memoria 64 GB 4 x 16 GB DDR5 6600 MHz
Corsair Carbide 275R ATX Midi-Tower Gaming Nero
Asus ROG Loki SFX-L 1000W Platinum 24-pin ATX Nero, Argento - Scatola aperta , prodotto nuovo
Samsung MZ-77Q4T0 2.5" 4TB SATA III V-NAND MLC
Asus TUF-RTX4080-16G-GAMING NVIDIA GeForce RTX 4080 16 GB GDDR6X
Microsoft Windows 10 Pro DVD 64bit 1pk ITA OEM
Samsung 980 PRO M.2 1 TB PCI Express 4.0 V-NAND MLC NVMe
2 x DeckLink 8K PRO - Blackmagic
DeckLink Mini Monitor 4k - Blackmagic
Thanks to all
Kayo33
#2 Posted : Thursday, November 30, 2023 2:16:59 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
no, it's not good
the processor doesn't match with the motherboard
i9-13900KS = socket 1700
socket LGA4677 for xeon processors
Kayo33
#3 Posted : Thursday, November 30, 2023 2:32:22 AM(UTC)
Kayo33
you also need to change the sata III for an M.2
1 x M.2 4.0x4 4 Tb for replay rec
1 x M.2 4.0x4 1 or 2 Tb for windows
for 8 replay cams (1080p)
from Asus, socket 1700
with 1 decklink quad 2:
ASUS ProArt Z790-CREATOR WIFI
read the motherboard manuals first, depending on your configuration needs, as some slots may share bandwidth or disable each other
neural
#4 Posted : Thursday, November 30, 2023 8:11:04 AM(UTC)
neural
Italy
Thanks Kayo33,
I didn't found Xeon processors available from my suppliers.
What do you think about this configuration?
Processor Intel Core i9-13900KS 36 MB
Motherboard Asus PROART Z790-CREATOR WIFI LGA 1700 ATX
SSD Samsung 980 PRO M.2 1 TB PCI Express 4.0 V-NAND MLC NVMe
SSD Seagate FireCuda 530 M.2 4 TB PCI Express 4.0 3D TLC NVMe
Schede video Asus ROG -STRIX-RTX4080-O16G-GAMING GeForce RTX 4080 16 GB GDDR6X
Memoria RAM Corsair Corsair VENGEANCE memoria 64 GB 2 x 32 GB DDR5 4800 MHz
Hard Disk Western Digital Purple Pro 3.5" 10 TB SATA III
COUGAR DarkBlader-S Full-Tower Nero, Arancione
Alimentatori MSI MPG A1000G PCIE5 Alimentatore 1000W ATX Modulare Certificato 80 Plus Gold Completamente Modulare
1 x Decklink Mini Monitor
1 x Decklink quad 2
Thank you very much
Kayo33
#5 Posted : Friday, December 1, 2023 2:41:39 AM(UTC)
Kayo33
i9-14900K for cpu, cheaper than 13900KS for the same performance
DDR5-5600 Mhz for ram, natively managed by the cpu
and a large cooling system for the cpu
high-end ventirad (be quiet! Dark Rock Pro 5) or AIO 360 (Asus ROG Strix LC II 360 V2), these are examples
and efficient fans for the case, see the box manual to see what is possible
