souban
#1 Posted : Wednesday, November 29, 2023 12:28:51 AM(UTC)
souban
India
I have Created a title using GT designer which is animated in and out but when i added input it was not looping i have to click manually to show the transition in and out
please help anyone with script or any other idea that i need to animate in and stay for 10sec then i need to animate out after 5sec this again animate in
in this way i need to loop that title
#2 Posted : Wednesday, November 29, 2023 1:28:10 AM(UTC)
This totally normal transition in and out are just what they say, these animations happen when a transition is happening a loop is not available
pretty easy with a script : set a do while true in the script containing an animation In , a sleep(10000) , animate Out, Sleep(5000), loop
Check the "scripting for dummies" post in this forum
OR
Use a few trigger in the title input : OnOverlayIn do an overlayOut after x seconds, On OverlayOut do an overlay IN after x seconds
Other ideas: depends on the animation you are looking for
BTW the title of the post implied you were talking about a (TEXT) TICKER ;-)
souban
#3 Posted : Friday, December 1, 2023 2:25:14 AM(UTC)
souban
India
dim main = "firstTitle.gtzip"
dim second = "firstTitle.gtzip"
do while true
API.Function("OverlayInput1In",Input:=main)
API.Function("OverlayInput1In",Input:=second )
Sleep(5000)
API.Function("OverlayInput1Out",Input:=main)
API.Function("OverlayInput1Out",Input:=second )
Sleep(4000)
loop
i want to make that main input in at number 2 tab
and second in number 3 tab how can i achieve that please help out
first input in number 2, second at number 3 and third at number i need and animate in and out together
#4 Posted : Friday, December 1, 2023 3:12:04 AM(UTC)
do while true
Sleep(5000)
Sleep(4000)
loop
check the available shortcuts ! Change the number in OverlayInput In/Out
kross
#5 Posted : Friday, December 1, 2023 5:53:09 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
I have not checked this for correctness. But I see some things wrong. First, your two variables at the top are both the same. Copy/paste error I'm sure. Secondly, you need to alternate between overlay in and overlay out. Also, the overlay out shortcut doesn't take any parameters.
Code:
dim second = "secondTitle.gtzip"
do while true
  API.Function("OverlayInput1Out")
  Sleep(5000)
  Sleep(4000)
loop
You might have to put a delay after the overlay out and before the overlay in, to give it time to execute.
It's possible you don't even need the overlay out. When you call overlay in with a new input, I think that vMix will switch to that new input. I don't know if it will do the in/out transition effects, though. That's what you would need to test.
#6 Posted : Friday, December 1, 2023 6:25:40 AM(UTC)
Doing an OverlayIn to replace an input allready in overlay will cut out the first (not animate out)
OP was asking the Overlay multiple inputs at once like on 1,2 and 3 (hence the "Change the number in OverlayInput In/Out" )
nice catch on the variables
kross
#7 Posted : Friday, December 1, 2023 6:28:27 AM(UTC)
kross
Oh! Then I completely misread the question. Feel free to ignore me. :)
#8 Posted : Friday, December 1, 2023 8:04:50 AM(UTC)
Why? you gave a few good pointers
