GT
Gt Text Loop
Joined: 11/27/2023(UTC) Posts: 2  Location: mangalore
I have Created a title using GT designer which is animated in and out but when i added input it was not looping i have to click manually to show the transition in and out please help anyone with script or any other idea that i need to animate in and stay for 10sec then i need to animate out after 5sec this again animate in in this way i need to loop that title
Originally Posted by: souban  I have Created a title using GT designer which is animated in and out but when i added input it was not looping i have to click manually to show the transition in and out This totally normal transition in and out are just what they say, these animations happen when a transition is happening a loop is not available Quote: please help anyone with script or any other idea that i need to animate in and stay for 10sec then i need to animate out after 5sec this again animate in in this way i need to loop that title
pretty easy with a script : set a do while true in the script containing an animation In , a sleep(10000) , animate Out, Sleep(5000), loop Check the "scripting for dummies" post in this forum OR Use a few trigger in the title input : OnOverlayIn do an overlayOut after x seconds, On OverlayOut do an overlay IN after x seconds Other ideas: depends on the animation you are looking for BTW the title of the post implied you were talking about a (TEXT) TICKER ;-)
dim main = "firstTitle.gtzip" dim second = "firstTitle.gtzip" do while true API.Function("OverlayInput1In",Input:=main) API.Function("OverlayInput1In",Input:=second ) Sleep(5000) API.Function("OverlayInput1Out",Input:=main) API.Function("OverlayInput1Out",Input:=second ) Sleep(4000) loop i want to make that main input in at number 2 tab and second in number 3 tab how can i achieve that please help out  11.png (11kb) downloaded 4 time(s).first input in number 2, second at number 3 and third at number i need and animate in and out together
Originally Posted by: souban  dim main = "firstTitle.gtzip" dim second = "firstTitle.gtzip" do while true API.Function("OverlayInput1In",Input:=main) API.Function("OverlayInput1In",Input:=second ) Sleep(5000) API.Function("OverlayInput1Out",Input:=main) API.Function("OverlayInput1Out",Input:=second ) Sleep(4000) loop i want to make that main input in at number 2 tab and second in number 3 tab how can i achieve that please help out  11.png (11kb) downloaded 4 time(s).first input in number 2, second at number 3 and third at number i need and animate in and out together check the available shortcuts ! Change the number in OverlayInput In/Out
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
I have not checked this for correctness. But I see some things wrong. First, your two variables at the top are both the same. Copy/paste error I'm sure. Secondly, you need to alternate between overlay in and overlay out. Also, the overlay out shortcut doesn't take any parameters. Code:dim main = "firstTitle.gtzip"
dim second = "secondTitle.gtzip"
do while true
API.Function("OverlayInput1Out")
Sleep(5000)
Sleep(4000)
loop
You might have to put a delay after the overlay out and before the overlay in, to give it time to execute. It's possible you don't even need the overlay out. When you call overlay in with a new input, I think that vMix will switch to that new input. I don't know if it will do the in/out transition effects, though. That's what you would need to test.
Doing an OverlayIn to replace an input allready in overlay will cut out the first (not animate out) OP was asking the Overlay multiple inputs at once like on 1,2 and 3 (hence the "Change the number in OverlayInput In/Out" ) Quote:i want to make that main input in at number 2 tab and second in number 3 tab how can i achieve that please help out
nice catch on the variables
Originally Posted by: doggy  OP was asking the Overlay multiple inputs at once like on 1,2 and 3 (hence the "Change the number in OverlayInput In/Out" ) Oh! Then I completely misread the question. Feel free to ignore me. :)
Originally Posted by: kross  Originally Posted by: doggy  OP was asking the Overlay multiple inputs at once like on 1,2 and 3 (hence the "Change the number in OverlayInput In/Out" ) Oh! Then I completely misread the question. Feel free to ignore me. :) Why? you gave a few good pointers
GT
Gt Text Loop
