Systems
what system configuration do you recommend
Hello, Which motherboard do you currently recommend for building a high-end system with 4k cameras and replays? The Gigabyte X299 Master board recommended on the website is no longer available on the market!! Greetings Dietmar
Joined: 10/20/2023(UTC) Posts: 158  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
how many 4k inputs ? 4k30 or 4k60 ? note: 4k replay in vmix is limited to 2 4K in
for 4 inputs 4k60, many socket 1700 or am5 motherboards can do the trick.
all you need is 2 pcie slots on motherboard, 1 of which must be pcie 3.0 x8 minimum (ASRock X670E Taichi for example)
gpu on pcie slot x8 + 1 capture card with 4 in 4k60p on the 2nd slot pcie x8 (blackmagic 8k pro or quad hdmi card for example)
an i9 or ryzen 9 processor, ddr5 ram and ssd m.2 5.0x4 or 4.0x4
for example with an Asus ASUS ProArt Z790-CREATOR
pcie 1 = 5.0 x16 (x8) = graphic card pcie 2 = 5.0 x16 (x8) = capture card 4 x 4k60p
examples of motherboards for 4 x 4k60p inputs intel 1700 :
ASRock Z790 Taichi Lite ASRock Z790 Taichi ASUS ROG MAXIMUS Z790 HERO ASUS ROG MAXIMUS Z790 APEX ENCORE MSI MEG Z790 ACE MSI MEG Z790 ACE MAX
amd AM5 :
ASUS ProArt X670E-CREATOR WIFI ASUS ROG CROSSHAIR X670E HERO MSI MPG X670E CARBON WIFI MSI MEG X670E ACE ASRock X670E Taichi Carrara ASRock X670E Taichi
or to stay in the x299 tradition you need to start with platforms for ryzen threadripper or intel xeon
Systems
