Joined: 11/27/2023(UTC) Posts: 1  Location: Marlborough MA
Long story short, I used this laptop for vmix using the focusrite 212i hardware. Its great and it works 100% fine. But I decided to use a new device for using the vmix so that i could use more options of livestream. In the old computer the siganl from the focusrite showed up as Audio Analogue 1+2. But when i just switched the sane cable to a new computer it shows up as Microfone. the worst part its that the with the new computer the signal isnt loud, or effective. Ive tired uisng the type c cables. Ive tried. Restarting the computer, ivew tried restarting the software, and now nothing worrks. Any tips and advice i would apprecite
Joined: 12/19/2020(UTC) Posts: 57  Location: London Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
You need to install the Focusrite software (Focusrite Control) on the 'new device'.
