28 Pages«<2223242526>»
#461 Posted : Tuesday, November 21, 2023 5:40:21 AM(UTC)
Originally Posted by: Salvatore Go to Quoted Post
Hy guys,
It is possible to change a Text value by Looking for name and Not for the Index nr?
Code:
API.Function("ChangeCountdown",Input:="Timer Centre.gtzip", SelectedIndex:="0", Value:="00:05")
Something like:
API.Function("ChangeCountdown",Input:="Timer Centre.gtzip", Selectet Name:="countdown1.Text", Value:="00:05")
Yes
/ see post #5
// you answered your own question
Salvatore
#462 Posted : Tuesday, November 21, 2023 6:26:11 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
Hy guys,
Code:
Something like:
API.Function("ChangeCountdown",Input:="Timer Centre.gtzip", SelectetName:="countdown1.Text", Value:="00:05")
Yes
/ see post #5
unfortunately this doesn't work. That's why I asked
You mean to change the Countdown selected by Name the API.Function is „SetText… and Not ChangeCountdown"…
I give it a try
#463 Posted : Tuesday, November 21, 2023 7:04:40 AM(UTC)
Hy guys,
Code:
Something like:
Yes
/ see post #5
I give it a try
ChangeCountdown changes the time when its allready running and time is in the HH:mm:ss format
Also check spelling (SelectedName with a d)
a good idea is to verify a function by use of its shortcut
The question was in regards to be able to use the slectedName not in regards to a countdown which has multiple functions to control it (change,se, start , pause etc
SetText is the most basic function to populate a title field and is NOT related to a countdown
nikosman88
#464 Posted : Wednesday, November 22, 2023 10:37:46 PM(UTC)
nikosman88
Greece
Was thanked: 99 time(s) in 95 post(s)
Originally Posted by: nikosman88 Go to Quoted Post
Hello guys. Is there any way the number of the overlay channel to be transcoded in to the real input name? I want to keep logs of what im playing in my overlay channels so i used as base this script
https://forums.vmix.com/...or-commercials#post99914 and this https://forums.vmix.com/...ng-for-Dummies#post71167
the script is this for example for overlay1 channel
Ιt work ok but is there any way in txt log file instead of the input number to record the input name? I need somehow to transcode the input number from overlay api xml record to the input name and then write it to the txt file. Is this possible? Thank you
get the Input's innertext matching the number
Code:
'X is the variable holding the input number
Dim name as string = x.SelectSingleNode("//input[@number=" & X & "]").InnerText
maybe im stupid but i cant manage how to do it.
#465 Posted : Wednesday, November 22, 2023 10:55:57 PM(UTC)
Code:
What is the issue? Chatgpt not giving an answer?
OP asked to retrieve the name op an input that is refered to by the number retrieved from the overlay given from the api xml.
nikosman88
#466 Posted: : Wednesday, November 22, 2023 11:20:27 PM(UTC)
nikosman88
Greece
Code:
The issue is that i cant understand the message error it gives to me. it says operator "is not defined for types 'string' and 'system.xml.xmlDocument'. Chatgpt give some answers that in theory may work but unfortunatelly doesnt know the limitations that vmix script vb.net console have that not recognise correct that functions that exist in vb.net like end sub and etc.. So i hope that vmix in version 28+ will include and support 100% full vb.net support so people that are really dummies like me,will do the job via the new technology if they try
#467 Posted : Thursday, November 23, 2023 3:02:27 AM(UTC)
showing the code might help us figure it out
keep in mind that when trying to read the API XML and the data searching for is empty a script will throw an error. One should take that in account within a script to catch this to avoid the script crashing.
If one wants to take full advantage of vb.net better create scripts outside of vMix (using visual studio) .This will allow you to create functions and subs. Vmix dosnt allow subs etc , see helpfiles
Doubt highly vMix will ever make a visual studio substitude
nikosman88
#468 Posted : Thursday, November 23, 2023 3:21:55 AM(UTC)
nikosman88
Greece
Code:
' Script von Mats Julian Steffens
' www.lvstrm.de
' Log everything you are playing
dim dateinamealt as string = ""
do
dim datum as string
datum = DateTime.Now.ToString("yyMMdd")
dim filename as string
filename="C:\vMix overlay\overlay1\"+datum+"-vmixlog.txt"     'Where to save the file
If (Not System.IO.File.Exists(filename)) Then
   My.Computer.FileSystem.WriteAllText(filename, " ", True)
End If
dim timestamp as string
timestamp = DateTime.Now.ToString("dd/MM/yy HH:mm:ss")
dim xml as string = API.XML()
dim ovl1input as string = ""
x.loadxml(xml)
ovl1input = (x.SelectSingleNode("//overlays//overlay[1]").InnerText)
dim dateiname as string = (x.SelectSingleNode("//overlays//overlay[1]").InnerText)
if (ovl1input = nothing)
'we don't have 2 PIP overlays, no point in continuing then
end if
dim inputnamelaenge as string
If (ovl1input = dateiname) Then
    inputnamelaenge = 0
Else
    inputnamelaenge = ovl1input.Length()+3
End If
dim inputString as string
'Datei schreiben
If (dateinamealt <> dateiname) Then
    inputString = timestamp + " " + dateiname.Substring(inputnamelaenge) + Environment.NewLine
    Console.WriteLine(inputString)
    My.Computer.FileSystem.WriteAllText(filename, inputString, True)
    dateinamealt = dateiname
End If
sleep(1000)
loop
i know that i must somehow assign the X to take dynamically the name of the input but dont understand how to do this
#469 Posted : Thursday, November 23, 2023 8:33:58 PM(UTC)
Code:
A good idea is to learn some basics about vb.net (or any language) and the use of variables instead of relying on chatgpt or willy nilly throwing something into existing copied code
line 1 and 2 above do exactly the same thing : putting the inputnumber used as overlay in a (different) variable
As mentioned before "'X is the variable holding the input number" and you are using a different variable (ovl1input and dateiname , but have not define X)
So need to replace the variable reference (X) to yours in the example code
Code:
Dim name as string = x.SelectSingleNode("//input[@number=" & ovl1input & "]/@title").InnerText
console.writeline(name )
Mind the little addition/correction by the added /@title
Also there is no error trapping (Try..Catch) included hence when calling this and there is no overlay active you will get an error/script crash
Also a good idea to check returns is to display the results in the console for instant debugging
nikosman88 on 11/24/2023(UTC)
nikosman88
#470 Posted : Friday, November 24, 2023 12:02:57 AM(UTC)
nikosman88
Greece
Code:
Code:
Thank you very much. It work perfect. Yes it crash when there is no overlay but i can very easy workaround over it. Yes you`re right about learning the basics of a language but this seems to me, like a mountain even higher from everest! Google of course has all the needed info but someone needs years to read all that info. AI is not the solution for everything and if you see my posts here in forum. i never throw an AI answer without a bit of explain or without having it try first myself. Anyway thank you again, you saved me another one time!
randigusti
#471 Posted : Saturday, December 2, 2023 8:15:35 AM(UTC)
randigusti
Indonesia
Hello , can you help me with this situation :
if countdown on the gt 10 second left then the color change
nikosman88
#472 Posted : Saturday, December 2, 2023 9:12:27 AM(UTC)
nikosman88
Greece
Hi you made double post. Personally i give you possible answers in the other thread you made
#473 Posted : Saturday, December 2, 2023 9:14:29 AM(UTC)
Why post same question in 2 different posts ?
What have you been able to figure out seeing you posted in this thread after reading through it ?
Have you tried a search ?
https://forums.vmix.com/...ock-for-events#post83255
https://forums.vmix.com/...ng-for-Dummies#post99770
randigusti
#474 Posted : Sunday, December 3, 2023 4:35:33 AM(UTC)
randigusti
Indonesia
Hello sorry before i double my question , i dont know i send double. And i have try to searc but cant find it. But your answer help me , thankyou for that. Now i have new case , hope you can help me.
My situasion like this :
I have video input , how i change the video input by directory ? Example i have video input with this directory “C:/Videos/map.mp4” can you help me to change the video input with just change the “map.mp4” on the directory so i have many videos in “C:/Videos/“ i want to call the video on that directory alternately with just one input on vmix. but i change the directory through excel or google sheet or notepad or other beginner editor text. Sorry if my english not good
nikosman88
#475 Posted : Sunday, December 3, 2023 7:18:20 AM(UTC)
nikosman88
Greece
Hello. Vmix cannot change "on the fly" a input. Yes there is in the input settings in the up right corner the button "change" but this work only manual way. Something in an auto way that vmix api commands support is add a video input or remove an existing video input. With this in mind yes it is possible to do what you need if you know how to do it. Some steps you may possible have to follow
1. Make a new title as vmix input and link to it the datasource that will have the path of the videos or any other info that needs
2.Make a script that will read the info from the title and when the text changes (according to what you select in datasource manager) will do a search in the c:\videos folder and it will send the command to add the new name video input and remove if need the old one
In this thread you will find some other examples to start. In theory is something like this. In practice if you never make script again and you need it quickly, you need to study a lot or pray a guru-expert guy of this thread will give you the whole solution
Or the most simple way make a list input,put there all your videos,disable the auto-next if not need and do from there the whole play-pause
#476 Posted : Monday, January 15, 2024 1:43:16 AM(UTC)
Countdown to date and time with auto reset/advance
Countdown to date and time with optional function(s) trigger resetting it to next date/time interval . example: every seven days at same time
Code:
Dim enddate As DateTime = DateTime.Parse("2024-1-21 10:30:00")
Dim startdate As DateTime
Dim ts As TimeSpan
Dim count as string
Do while true
  startdate = DateTime.Parse(Date.Now)
  ts = enddate.Subtract(startdate)
  if enddate >= startdate
    count=CStr((ts.Days) & " days " &  CStr(ts.Hours)) & " Hrs, " & CStr(ts.Minutes) & " mins, " & CStr(ts.Seconds) & " secs"
    API.Function("SetText",Input:="9",SelectedName:="Headline.Text",Value:=count)
    'console.writeline(count)
    sleep(1000)
  else
    ' any function acting as trigger when countdown is finished
    ' and resetting countdown
    enddate=enddate.AddDays(7)
  end if
Loop
dmwkr on 1/16/2024(UTC)
bd9565
#477 Posted : Saturday, January 20, 2024 10:01:42 PM(UTC)
bd9565
Russian Federation
Dear guys.
How can I suspend / hibernate / shutdown my Windows10 PC with the vMix script ?
#478 Posted : Sunday, January 21, 2024 12:56:20 AM(UTC)
Originally Posted by: bd9565 Go to Quoted Post
Dear guys.
Not sure if this for serious useage or to "prank" a system but google can give you the answer (hence i dont post the code just yet)
Hint: vb.net shutdown windows
bd9565
#479 Posted : Sunday, January 21, 2024 3:16:31 AM(UTC)
bd9565
Russian Federation
Thank you. It's not a prunk. I really need to suspend PC at the end of night stream.
I found the solution
Code:
 Process.Start("c:\windows\system32\rundll32.exe", "powrprof.dll,SetSuspendState")
#480 Posted : Sunday, January 21, 2024 3:24:18 AM(UTC)
Code:
well this works for shutting down (change value of 00 for time delay) . it calls shutdown.exe
Code:
Process.Start("shutdown", "-s -f -t 00")
bd9565 on 1/21/2024(UTC)
Guest (12)
