pba
#1 Posted : Saturday, October 10, 2020 8:23:44 PM(UTC)
pba
Was thanked: 24 time(s) in 20 post(s)
Hello Guys,
I have a question regarding the mediafiles: is there any way to use a mediafile in VMIX with multiple audio tracks? I tried with MP4, MPEG2, MKV, ProRes formats without any success, only the first 2 channels are available in VMIX. With Decklink video input its works fine, but not with the media files.
This can be really usefull for the multi-language streams... is there any workaround for this? Or any file format which is usable in vmix with multiple audio channels?
Thanks!
marcmontanes
#2 Posted : Monday, November 20, 2023 10:43:27 PM(UTC)
marcmontanes
Spain
any news on that question?
Thanks,
Peter1000
#3 Posted : Tuesday, November 21, 2023 8:23:04 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
EDIT:
if this is not another entry from a bot...
only now seen that he hasn't had a post yet
i use Sony XDCAM or Apple ProRes files with 8 tracks with no problem.
In the Channel Matrix you can see, if your Video has more then 2 channels
You have to root the additional tracks 3-8 to Bus A-C (Audio Settings of the Input/ Channel Matrix
i think xMix also supports other formats with up to 8 audios (see help files)
also i can choose, which audios i record in the vMix recorder, M/A/MABC etc.
so, multiple audios should not be a problem
