Media files with multiple audio tracks
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Hello Guys,
I have a question regarding the mediafiles: is there any way to use a mediafile in VMIX with multiple audio tracks? I tried with MP4, MPEG2, MKV, ProRes formats without any success, only the first 2 channels are available in VMIX. With Decklink video input its works fine, but not with the media files.
This can be really usefull for the multi-language streams... is there any workaround for this? Or any file format which is usable in vmix with multiple audio channels?
Thanks!
Joined: 11/20/2023(UTC) Posts: 1  Location: Barcelona
any news on that question?
Thanks,
Joined: 1/25/2019(UTC) Posts: 332  Thanks: 24 times Was thanked: 85 time(s) in 65 post(s)
EDIT: if this is not another entry from a bot... only now seen that he hasn't had a post yet
i use Sony XDCAM or Apple ProRes files with 8 tracks with no problem. In the Channel Matrix you can see, if your Video has more then 2 channels You have to root the additional tracks 3-8 to Bus A-C (Audio Settings of the Input/ Channel Matrix i think xMix also supports other formats with up to 8 audios (see help files) also i can choose, which audios i record in the vMix recorder, M/A/MABC etc. so, multiple audios should not be a problem
