progresstv
#1 Posted : Tuesday, July 29, 2014 6:25:25 AM(UTC)
progresstv
This Is the smallest vMix for streaming:
Features
Case 1U rack
mb Intel with I7 CPU 16/32 Mb ram
Internal SSD 120Gb for Win
Built in 1024 Intel Graphic card, 2 1Gb Lan, 2 Wireless, Blutooth, 4x 3.0 USB
2X HDMI 1X DVI/VGA
1X Capture BM Quad/duo/Dceklinc(as needed) SDI Input
Tested H24 streaming at 1800Mbt to private videoserver fo 1 week no issue
any questions?
thanks 1 user thanked progresstv for this useful post.
richardgatarski on 7/29/2014(UTC)
ovinas
#2 Posted : Tuesday, July 29, 2014 7:12:34 AM(UTC)
ovinas
progresstv wrote:
any questions?
Yes, one question. Is it really smaller than my MacMini running Win 8.1 with a BM DeckLink Mini Recorder Thunderbolt? ;-)
In case of just one needed capture input I would think the MacMini is 4 times smaller.....
progresstv
#3 Posted : Tuesday, July 29, 2014 7:38:02 AM(UTC)
progresstv
ovinas wrote:
progresstv wrote:
any questions?
I'm sure the macmini is smaller but:
Does not have two HDMI for dual monitor + vga monitor
It does not have two network cards 1Gb
The advantage of this solution, is that can be mounted in a small flycase(suitcase) already
wired with Monitor 24" ready to use.
Ludovico
r@wisla
#4 Posted : Tuesday, July 29, 2014 8:04:10 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
Quite nice :)
What's the i7 there?
What was the streaming resolution you tested and the CPU usage?
ovinas
#5 Posted : Tuesday, July 29, 2014 8:23:18 AM(UTC)
ovinas
progresstv wrote:
This Is the smallest vMix for streaming:...
...Does not have two HDMI for dual monitor + vga monitor
It does not have two network cards 1Gb...
But this is not really necessary for just streaming.
progresstv
#6 Posted : Tuesday, July 29, 2014 8:26:56 AM(UTC)
progresstv
Cpu I7-3770K 3.5Ghz
When tested 1800Kbit at 720X576
Cpu usage 2-3%
Now streaming at 500Kbit on www.webchanneltv.eu
progresstv
#7 Posted : Tuesday, July 29, 2014 8:31:11 AM(UTC)
progresstv
The purpose of this case is for the following.
This is a prototype
r@wisla
#8 Posted : Tuesday, July 29, 2014 8:34:54 AM(UTC)
r@wisla
progresstv wrote:
Cpu I7-3770K 3.5Ghz
Cpu usage 2-3%
Thanks. No problems with the heat in such tiny case?
Try 720p @2.5 - 3 Mbps :)
+ check the CPU Usage on Windows Task Manager, not vMix. I guess it only shows vMix's CPU usage.
richardgatarski
#9 Posted : Tuesday, July 29, 2014 11:25:32 AM(UTC)
richardgatarski
Was thanked: 297 time(s) in 250 post(s)
really cool! thanks progresstv for sharing :)
watching right now, seems you have missed to turn on the deinterlacer (small jagged artefacts in when things move around).
progresstv
#10 Posted : Tuesday, July 29, 2014 11:28:19 AM(UTC)
progresstv
You are right I'am not deinterlacing.
tgdzapa1
#11 Posted : Wednesday, August 6, 2014 3:21:31 AM(UTC)
tgdzapa1
ciao ragazzi
small & nice. thanks for demonstration.
i see your sat-car. with which sat service do you work?
does your program runs on tv or just on ghe web?
thanks for reply.
greetings from switzerland
patrick
h2video.nl
#12 Posted : Wednesday, August 6, 2014 6:32:11 AM(UTC)
h2video.nl
nice system: small is beautiful...
can you make a photo of the back and inside. interested to see how you put the capture card in...
donyou have more specs: motherboard etc...
what cooling fan etc.
how does it perform in a car with 35c heat outside for a whole day in the sun... need extra cooling ?.
greetings stefan
ps working in that direction but i also want to integrate the monitor in one compact system. and affordable... any ideas?
progresstv
#13 Posted : Wednesday, August 6, 2014 10:15:07 AM(UTC)
progresstv
tgdzapa1 wrote:
ciao ragazzi
thanks for reply.
patrick
Hi the service can be TOOWAY or as in my case have booking on needed ENG service.
example: Tomorrow I will need to LIVE Broadcast for a Local television
I booked 2Mb in upload for the needed time (2hours).
The request was 720X576 in SD @ 1,6mb.
For web bradcasting only one of these PC are needed for TV Live broadcasting You need one for encoding
and another for decoding placed in TV station.
1.6 - 1.8 mb gives a good SD quality for Television broadcasting.
Adriankey4
#14 Posted : Wednesday, August 6, 2014 10:40:01 AM(UTC)
Adriankey4
Jamaica
Where you got that dish?
LG
#15 Posted : Wednesday, August 6, 2014 12:16:50 PM(UTC)
LG
progresstv wrote:
tgdzapa1 wrote:
ciao ragazzi
thanks for reply.
patrick
depending in if there is a lot of motion and moving parts
the tour the france will be a little bit of a problem. ( broadcast quality wise )
progresstv
#16 Posted : Wednesday, August 6, 2014 1:17:44 PM(UTC)
progresstv
I do not do France tour not even Italian Tour but surely I do Soccer games where I have tested it (and not only once)
It works fine no istant block no pixeling thats good for who has low budget.
If you want I can find one of the soccer files game recorded in tv station and posted on youtube.
HighViewSport
#17 Posted : Monday, December 8, 2014 7:05:55 PM(UTC)
HighViewSport
Thanks progresstv for sharing with us. I like this a lot. I have been thinking about having a separate streaming pc.
Can I ask what spec machine you have for your multi-camera switching?
I am trying to find ways to build a portable simple solution for our sports productions. Currently I pack every thing is boxes.
Long setup. I am looking for a simple and fast solution including a way to have a monitor built in. Any suggestions?
I like these but they are extremely expensive: http://www.ubergizmo.com...ugged-portable-computer/
Thanks Bryan
Guest (4)
