Showcase
smallest vMix Computer for live streaming
This Is the smallest vMix for streaming: Features Case 1U rack mb Intel with I7 CPU 16/32 Mb ram Internal SSD 120Gb for Win Built in 1024 Intel Graphic card, 2 1Gb Lan, 2 Wireless, Blutooth, 4x 3.0 USB 2X HDMI 1X DVI/VGA 1X Capture BM Quad/duo/Dceklinc(as needed) SDI Input Tested H24 streaming at 1800Mbt to private videoserver fo 1 week no issue any questions?
 1 user thanked progresstv for this useful post.
progresstv wrote:any questions? Yes, one question. Is it really smaller than my MacMini running Win 8.1 with a BM DeckLink Mini Recorder Thunderbolt? ;-) In case of just one needed capture input I would think the MacMini is 4 times smaller.....
ovinas wrote:progresstv wrote:any questions? Yes, one question. Is it really smaller than my MacMini running Win 8.1 with a BM DeckLink Mini Recorder Thunderbolt? ;-) In case of just one needed capture input I would think the MacMini is 4 times smaller..... I'm sure the macmini is smaller but: Does not have two HDMI for dual monitor + vga monitor It does not have two network cards 1Gb The advantage of this solution, is that can be mounted in a small flycase(suitcase) already wired with Monitor 24" ready to use. Ludovico
Joined: 8/5/2013(UTC) Posts: 280  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Quite nice :)
What's the i7 there?
What was the streaming resolution you tested and the CPU usage?
progresstv wrote:This Is the smallest vMix for streaming:... ...Does not have two HDMI for dual monitor + vga monitor It does not have two network cards 1Gb... But this is not really necessary for just streaming.
Cpu I7-3770K 3.5Ghz When tested 1800Kbit at 720X576 Cpu usage 2-3% Now streaming at 500Kbit on www.webchanneltv.eu
ovinas wrote:progresstv wrote:This Is the smallest vMix for streaming:... ...Does not have two HDMI for dual monitor + vga monitor It does not have two network cards 1Gb... But this is not really necessary for just streaming. The purpose of this case is for the following.   This is a prototype
progresstv wrote:Cpu I7-3770K 3.5Ghz When tested 1800Kbit at 720X576 Cpu usage 2-3% Now streaming at 500Kbit on www.webchanneltv.eu Thanks. No problems with the heat in such tiny case? Try 720p @2.5 - 3 Mbps :) + check the CPU Usage on Windows Task Manager, not vMix. I guess it only shows vMix's CPU usage.
really cool! thanks progresstv for sharing :)
watching right now, seems you have missed to turn on the deinterlacer (small jagged artefacts in when things move around).
You are right I'am not deinterlacing.
Joined: 1/21/2014(UTC) Posts: 82 Location: sportwebtv.be
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
ciao ragazzi
small & nice. thanks for demonstration. i see your sat-car. with which sat service do you work? does your program runs on tv or just on ghe web?
thanks for reply.
greetings from switzerland patrick
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
nice system: small is beautiful...
can you make a photo of the back and inside. interested to see how you put the capture card in...
donyou have more specs: motherboard etc... what cooling fan etc.
how does it perform in a car with 35c heat outside for a whole day in the sun... need extra cooling ?.
greetings stefan
ps working in that direction but i also want to integrate the monitor in one compact system. and affordable... any ideas?
tgdzapa1 wrote:ciao ragazzi
thanks for reply.
Hi the service can be TOOWAY or as in my case have booking on needed ENG service. example: Tomorrow I will need to LIVE Broadcast for a Local television I booked 2Mb in upload for the needed time (2hours). The request was 720X576 in SD @ 1,6mb. For web bradcasting only one of these PC are needed for TV Live broadcasting You need one for encoding and another for decoding placed in TV station. 1.6 - 1.8 mb gives a good SD quality for Television broadcasting.
Joined: 1/5/2013(UTC) Posts: 36   Location: Jamaica Thanks: 102 times Was thanked: 3 time(s) in 3 post(s)
progresstv wrote:tgdzapa1 wrote:ciao ragazzi
thanks for reply.
Hi the service can be TOOWAY or as in my case have booking on needed ENG service. example: Tomorrow I will need to LIVE Broadcast for a Local television I booked 2Mb in upload for the needed time (2hours). The request was 720X576 in SD @ 1,6mb. For web bradcasting only one of these PC are needed for TV Live broadcasting You need one for encoding and another for decoding placed in TV station. 1.6 - 1.8 mb gives a good SD quality for Television broadcasting. depending in if there is a lot of motion and moving parts the tour the france will be a little bit of a problem. ( broadcast quality wise )
I do not do France tour not even Italian Tour but surely I do Soccer games where I have tested it (and not only once) It works fine no istant block no pixeling thats good for who has low budget. If you want I can find one of the soccer files game recorded in tv station and posted on youtube.
Joined: 11/12/2013(UTC) Posts: 115  Location: Wellington, New Zealand Thanks: 8 times Was thanked: 7 time(s) in 6 post(s)
Thanks progresstv for sharing with us. I like this a lot. I have been thinking about having a separate streaming pc. Can I ask what spec machine you have for your multi-camera switching? I am trying to find ways to build a portable simple solution for our sports productions. Currently I pack every thing is boxes. Long setup. I am looking for a simple and fast solution including a way to have a monitor built in. Any suggestions? I like these but they are extremely expensive: http://www.ubergizmo.com...ugged-portable-computer/Thanks Bryan
Showcase
