Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
Hello, In beginning this month i recorded performances of the culinary. But i have problem with master file. Then i watch i saw some "dropped frames". For analysis i use edius video editing software. When play frame by frame in slow motion i saw two equal frames and its like skip one frame. With audio no problem. All information(log and project settings files) and example of videos is there: https://www.dropbox.com/...ABNYp44q8dgQkrzNT1SfjvLaPlease help find where the problem can be. Sorry for my english... Arturas
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Hi, How are the cameras connected up to the computer? A couple of observations: 1. 11.0.0.63 is an old version of vMix. I would recommend upgrading to vMix 13 if possible or if you don't have an upgraded license, download vMix 11 below: http://www.vmix.com.au/download/vmix11.exe2. The recording log looks fine, so it is likely the setting mentioned below. 3. You have "Use VMR" ticked in the Capture window in vMix. This should not be ticked if your capture card is working properly as it does not synchronise frames and may be causing the dropped frames you are seeing. Regards, Martin vMix
I use 4 blackmagic design mini recorders. 3 cameras through SDI(jvc 750e) and 1 hdmi(sony hxr-nx3) connection.
Then unticking Use VMR will fix the problem. It is unticked by default. I would still recommend upgrading to vMix 13 if possible.
