WatsonPrunier
#1 Posted : Thursday, November 2, 2023 2:06:19 AM(UTC)
WatsonPrunier
Groups: Guests
I had to uninstall vMix 27 BETA because it kept, arbitrarily, disabling my audio interface. The only audio I could hear was barely out of my microphone and I was constantly rebooting vMix to get a consistent signal.
I tried the BETA for two (2) weeks. It is killing my live broadcast.
I have a RodeCaster Pro 2 that has been working flawlessly.
Also, back up and export your settings because every install deletes all your Scripts!
nikosman88
#2 Posted : Thursday, November 2, 2023 3:49:37 AM(UTC)
nikosman88
Greece
Was thanked: 64 time(s) in 60 post(s)
Hello. How do you insert the audio into vmix? Via 3,5mm jack or usb? You start with audio and stops during the show? For the scripts a solution is to have them also as local scripts so they store to your vmix preset and not globally in documents settings vmix folder and you dont loose them when you change between vmix versions.
#3 Posted : Thursday, November 2, 2023 3:54:26 AM(UTC)
Was thanked: 946 time(s) in 781 post(s)
Gues you missed the disclaimer ?
This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions.
Always has been like that
ryxyz on 11/2/2023(UTC)
WatsonPrunier
#4 Posted : Thursday, November 2, 2023 5:52:08 AM(UTC)
WatsonPrunier
Groups: Guests
Fortunately, I have my scripts saved but there were other configurations not saved. So, I backup as much as I can.
Also, If I log back into the PC under another account; it loses all the settings that a scripts
WatsonPrunier
#5 Posted : Thursday, November 2, 2023 5:53:13 AM(UTC)
WatsonPrunier
Groups: Guests
Most definitely! I love living on the edge! I knew it was a risk. I had most of my stuff backed up but learned I missed a few things to be added to a checklist.
#6 Posted : Thursday, November 2, 2023 12:28:04 PM(UTC)
Was thanked: 4207 time(s) in 1505 post(s)
We are not aware of any issues like this, and audio has been working fine in our tests.
Make sure you have the very latest beta installed and if the issue persists please send us an email explaining step by step on how to replicate.
eduardocfs on 11/11/2023(UTC)
