Beta Discussion
vMix 27 audio interface and settings issues
Groups: Guests
I had to uninstall vMix 27 BETA because it kept, arbitrarily, disabling my audio interface. The only audio I could hear was barely out of my microphone and I was constantly rebooting vMix to get a consistent signal.
I tried the BETA for two (2) weeks. It is killing my live broadcast.
I have a RodeCaster Pro 2 that has been working flawlessly.
Also, back up and export your settings because every install deletes all your Scripts!
Joined: 12/24/2021(UTC) Posts: 418 Location: athens Thanks: 116 times Was thanked: 64 time(s) in 60 post(s)
Originally Posted by: social_wp@outlook.com I had to uninstall vMix 27 BETA because it kept, arbitrarily, disabling my audio interface. The only audio I could hear was barely out of my microphone and I was constantly rebooting vMix to get a consistent signal.
Also, back up and export your settings because every install deletes all your Scripts! Hello. How do you insert the audio into vmix? Via 3,5mm jack or usb? You start with audio and stops during the show? For the scripts a solution is to have them also as local scripts so they store to your vmix preset and not globally in documents settings vmix folder and you dont loose them when you change between vmix versions.
Joined: 12/27/2012(UTC) Posts: 5,182 Location: Belgium Thanks: 288 times Was thanked: 946 time(s) in 781 post(s)
Originally Posted by: social_wp@outlook.com I tried the BETA for two (2) weeks. It is killing my live broadcast.
Gues you missed the disclaimer ? This is a preview release for those who like to live on the edge! There will still be some bugs, so it should not be used in productions. Quote: Also, back up and export your settings because every install deletes all your Scripts!
Always has been like that
Groups: Guests
Originally Posted by: nikosman88 Originally Posted by: social_wp@outlook.com I had to uninstall vMix 27 BETA because it kept, arbitrarily, disabling my audio interface. The only audio I could hear was barely out of my microphone and I was constantly rebooting vMix to get a consistent signal.
Also, back up and export your settings because every install deletes all your Scripts! Hello. How do you insert the audio into vmix? Via 3,5mm jack or usb? You start with audio and stops during the show? For the scripts a solution is to have them also as local scripts so they store to your vmix preset and not globally in documents settings vmix folder and you dont loose them when you change between vmix versions. Fortunately, I have my scripts saved but there were other configurations not saved. So, I backup as much as I can. Also, If I log back into the PC under another account; it loses all the settings that a scripts
Groups: Guests
Originally Posted by: doggy Originally Posted by: social_wp@outlook.com I tried the BETA for two (2) weeks. It is killing my live broadcast.
Always has been like that Most definitely! I love living on the edge! I knew it was a risk. I had most of my stuff backed up but learned I missed a few things to be added to a checklist.
Joined: 1/13/2010(UTC) Posts: 5,182 Location: Gold Coast, Australia Was thanked: 4207 time(s) in 1505 post(s)
We are not aware of any issues like this, and audio has been working fine in our tests. Make sure you have the very latest beta installed and if the issue persists please send us an email explaining step by step on how to replicate.
Martin vMix
Beta Discussion
