TYST TY-1500HD Switcher Reset
Joined: 10/24/2023(UTC) Posts: 1  Location: Calgary, Alberta Thanks: 1 times
Hi There
Just wondering if anyone knows of a reset for the TY-1500HD switcher. Worked fine until I updated VMIX to version 26, and now won't change to proper sources. I have re-installed the config files with no luck.
Any suggestions would be greatly appreciated.
Thanks,
John
Joined: 7/1/2020(UTC) Posts: 106  Location: Earth Was thanked: 23 time(s) in 20 post(s)
The TY-1500HD is hard coded to send certain MIDI commands as you press its buttons. As such there is no resetting this device AFAIK. If it isn't causing vMix to do what you want you will need to examine all of the shortcuts you have setup in vMix.
I will add that the way this panel uses its many shift functions leads to confusion in many users. Perhaps this may be the reason for your results.
 1 user thanked AudioGreg for this useful post.
Hi everyone, it is possible to customize the TYST1500HD a little using Central Control. My setup: Central Control, Bitfocus Companion, vMix. I don't use shortcuts directly in vMix.
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
Originally Posted by: IKONIK  Hi everyone, it is possible to customize the TYST1500HD a little using Central Control. My setup: Central Control, Bitfocus Companion, vMix. I don't use shortcuts directly in vMix. The newer HD1500 operates slightly differently than the V1s. It can be used in Central Control with the generic midi device or updated with proper configuration in upcoming new version of Central Control. BTW the other difference in the HD1500 V2 is the joystick is now midi, too, which is completely unusable until CC brings out their update as well.
Originally Posted by: fgolman  The newer HD1500 operates slightly differently than the V1s. Can you detail what is different about V2 of this device? besides the joystick...
Originally Posted by: AudioGreg  The TY-1500HD is hard coded to send certain MIDI commands as you press its buttons. As such there is no resetting this device AFAIK. If it isn't causing vMix to do what you want you will need to examine all of the shortcuts you have setup in vMix.
I will add that the way this panel uses its many shift functions leads to confusion in many users. Perhaps this may be the reason for your results. Can you expound on the shift functions? My top row seemingly randomly changes midi channels. I have no clue why.
