I'm looking for an OCR software that works well with VMIX. I need to capture a basketball score and insert it into a scoreboard designed with VMIX. I've seen scoreboard OCR software used a lot...but it's very expensive. Do you know of any cheaper ones that work well? Thank you.
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Start and stop by hand :-) You can't get around Scoreboard OCR. The software is worth every Euro!
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
If you're still looking for a cheaper software try ScoreSight.Live they have a free version, but also a pro version at a much more reasonable price than Scoreboard OCR
