Joined: 10/18/2023(UTC) Posts: 2   Location: St.Thomas, Ontario Thanks: 3 times
I am building an new PC for our churches livestream. Our current pc is 12 years old and limiting the stream quality, etc. Looking for feedback before i order the parts. (link to build parts below) Also, which video capture card would be best for this set-up?I'm stuck between: 1. AVerMedia Live Gamer 4K - 4Kp60 HDR Capture Card or 2. Elgato HD60 ProWe only use a single video camera input, Canon 4K Camcorder VIXIA HF G70. BUILD: https://newegg.io/a3722387Intel Core i7-13700K NZXT N7 Z790 LGA 1700 Motherboard DeepCool AK620 CPU Cooler 32GB DDR5 6400 Corsair Vengence RAM (2x16) Samsung 990 PRO 1TD PCIe SSD MSI Ventus GeForce RTX 3060 12GB Video Card (need 4 monitor support) Corsair 4000D Case with RM850e power supply Windows 11 home video capture card (only single input needed)
Originally Posted by: EFBCtech  I am building an new PC for our churches livestream. Our current pc is 12 years old and limiting the stream quality, etc. Looking for feedback before i order the parts. (link to build parts below) Also, which video capture card would be best for this set-up?I'm stuck between: 1. AVerMedia Live Gamer 4K - 4Kp60 HDR Capture Card or 2. Elgato HD60 ProWe only use a single video camera input, Canon 4K Camcorder VIXIA HF G70. BUILD: https://newegg.io/a3722387Intel Core i7-13700K NZXT N7 Z790 LGA 1700 Motherboard DeepCool AK620 CPU Cooler 32GB DDR5 6400 Corsair Vengence RAM (2x16) Samsung 990 PRO 1TD PCIe SSD MSI Ventus GeForce RTX 3060 12GB Video Card (need 4 monitor support) Corsair 4000D Case with RM850e power supply Windows 11 home video capture card (only single input needed) Hello.Personally i have i7 10700 and 1060gpu. I also have avermedia live gamer hd2 and im not happy how this card work with vmix. Actually not work properly with 1080p camera so i wouldnt suggest any product from avermedia combined with Vmix. Instead of this, i suggest blackmagic intensity pro 4k that work for input-output in Vmix excellent.Yes it is 2160p30 compared to 2160p60 of avermedia says but it work very good as it should
 1 user thanked nikosman88 for this useful post.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
The Intensity Pro is fine (I have a couple for capturing analog video) but I think a better choice from Blackmagic is the Decklink Mini Recorder 4K. It has HDMI and SDI input on the same card for extra flexibility, and doesn't have the unnecessary analog inputs. And it's cheaper. :)
You can add more as you add cameras.
We can discuss other options if you really need 60 fps at 4K.
 1 user thanked kross for this useful post.
would you consider these blackmagic cards a better option than the elgato 4k60 pro?
Originally Posted by: EFBCtech  would you consider these blackmagic cards a better option than the elgato 4k60 pro? The only reason I (and possibly other people too) recommend Blackmagic is because it's what I'm familiar with. Blackmagic have been making capture cards for many years (possibly decades), so they are well known and mature. Elgato is the new kid on the block. I just don't have any experience with them. They might be wonderful. They might be buggy. I have no idea.
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Hi, There is no need to get a 4K30p capture card, because while the HDMI output of the Canon VIXIA HF G70 4K camcorder is 4K30p, but this only applies during recording or when playing back files stored on the camera. During live capture, the HDMI output is limited to 1080p.   but for a setup with four 1080p or 4K30p cameras : Asus rog strix b650e-E gaming + Ryzen 7 7700x (or rog strix x670e-E gaming + Ryzen 7900x or 7950x if budget) 1 x ssd M.2 4.0 x4 for windows 1 x ssd M.2 5.0 x4 for multicorder 1 x ssd M.2 5.0 x4 (or pcie 5.0 x4 with x670e system) for rec pgm capture card = decklink mini recorder HD or 4K or elgato cam link pro = 4 x 1080p (or 4K30p) hdmi inputs (perfect if you want more cams later)
