SecondChurch
#1 Posted : Tuesday, October 17, 2023 9:52:35 AM(UTC)
SecondChurch
Hi, I pressed "Record" in vMix, and it starts recording, I see video in vMix, and I see the audio meters moving up and down, and a "recording" window pops up and says it is recording audio, but I play it back and there is no audio! just the video....what happened? If I open Zoom app and press "External" in vMix, I can record with great audio to Zoom cloud. It just won't record audio in "Record" mode.
WaltG12
#2 Posted : Wednesday, October 18, 2023 1:22:57 AM(UTC)
WaltG12
What are your recording settings within vMix?
SecondChurch
#3 Posted : Wednesday, October 18, 2023 11:49:15 PM(UTC)
SecondChurch
Not sure what vendor did. They said the new audio mixer now routes to Zoom application directly??? not through vMix. So "Record" won't work in vMix with audio just video. Weird! I have them coming back to resolve this issue. Crazy to take a feature away from a customer! They basically said you have to use Zoom app to get any audio recorded using Zoom record in application!
Roy Sinclair
#4 Posted : Thursday, October 19, 2023 7:31:23 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
Look at the bugs being reported about Zoom and Audio for the vMix 27 beta. In that version if you have audio Buses C or later defined then the zoom audio is lost so it may be you have stumbled on the bug that was found there (and fixed, but that doesn't fix vMix 26).
thanks 1 user thanked Roy Sinclair for this useful post.
SecondChurch on 10/19/2023(UTC)
Similar Topics
No Audio On Recording and Bad audio on External Record (General Discussion)
by cjpaul99 1/2/2018 2:00:17 PM(UTC)
