Beta Discussion
vMix 27 Preview Released!
Joined: 8/22/2020(UTC) Posts: 1 Location: Canberra Thanks: 1 times
Can Beta 27 be installed whilst maintaining 26 on a production machine?
Thankyou
Joined: 10/13/2012(UTC) Posts: 1,161 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
Originally Posted by: Simon Byrne Can Beta 27 be installed whilst maintaining 26 on a production machine?
Thankyou 27 will overwrite 26 if installed on the same machine. You can use 27 on a backup machine instead with either your current licence or a trial licence. Please note the licence conditions for this. You can revert back to 26 at any time by re-installing over 27.
2 users thanked ask for this useful post.
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4174 time(s) in 1498 post(s)
Originally Posted by: gostlund I felt I needed to contribute and help shape this... I'll be watching closely for updates and hopefully I can contribute further. Thanks for the response and feedback. Unfortunately it is difficult to tell what the specific issues are, best if you could stick to one issue and try to replicate it consistently then send a support report and drop us an email. Multiple Zoom MeetingsNote that multiple zoom meetings are not possible on a single computer and this is a Zoom imposed limitation. Audio FeaturesThings like original sound for musicians are not available to us at this time. Note that even if this was it would be limited to the audio vMix sends anyway, so each separate participant should still have control over their audio in the app as per normal, and the quality of that audio will then feed back into vMix. Gallery View etcvMix only has access to raw feeds of participants in an isolated manner, it doesn't have access to UI displays of different participants etc. Though you can bring in all the participants you need and put them in layers etc. Dynamic switching of participants is also difficult as raw feeds do not switch quickly enough for this to be viable at this time.
Originally Posted by: Quinton I am getting the latest beta to crash and restart quite regularly, by trying out a MoveMultiviewOverlay and SetMultiViewOverlay shortcut. Also it seems to be acting strangely if I press the shortcut key when the layers tab is open and I select the same shortcut, it will change the input starting at input 10 and go through the rest of the inputs one by one, always starting at input 10 again. This is just simple inputs like numbers as inputs.
EDIT: Just noticed a support report you sent earlier. Unfortunately your graphics driver is crashing, this is the error: D3DERR_DEVICEHUNG: Hardware adapter reset by OS (-2005530508) This is outside our control and an issue with the intel graphics or the driver. If it only started happening recently, could be a recent driver update in Windows.
Thanks: 11 times Was thanked: 7 time(s) in 4 post(s)
OK good to know, I do most of my testing on this little machine before moving it onto main machine. I will install onto my main and test further.
Originally Posted by: Quinton EDIT: Just noticed a support report you sent earlier. Unfortunately your graphics driver is crashing, this is the error: D3DERR_DEVICEHUNG: Hardware adapter reset by OS (-2005530508)
OK good to know, I do most of my testing on this little machine before moving it onto main machine. I will install onto my main and test further. Just installed on main machine now, can I ask why it does this "if" you have the layers window open. It works perfect when the layers window is closed, but I would like to have it open to see whats happening on the layers. Its just a simple shortcut for setmultiviewoverlay from 1,5 which should put input 5 which is the number 1 into input 1. Like I said it works when layers window is closed, but does weird things when its open if I keep pressing the same shortcut key.
Joined: 12/27/2012(UTC) Posts: 5,095 Location: Belgium Thanks: 284 times Was thanked: 922 time(s) in 761 post(s)
Originally Posted by: Quinton Just installed on main machine now, can I ask why it does this "if" you have the layers window open. It works perfect when the layers window is closed, but I would like to have it open to see whats happening on the layers. Its just a simple shortcut for setmultiviewoverlay from 1,5 which should put input 5 which is the number 1 into input 1. Like I said it works when layers window is closed, but does weird things when its open if I keep pressing the same shortcut key.
Could it have to do with the fact that in general shortcuts work on an active window (not the underlaying ones) ?
Keyboard shortcuts have never worked in the Input Settings window or any other window in vMix besides the main window. Use X-Keys etc if you require this, but even then the Input Settings window will not always update to reflect any changes.
So since the shortcuts you have assigned are number keys, this is just triggering the number shortcuts in Windows itself, which may activate or change dropdown boxes for example.
Originally Posted by: admin Keyboard shortcuts have never worked in the Input Settings window or any other window in vMix besides the main window. Use X-Keys etc if you require this, but even then the Input Settings window will not always update to reflect any changes.
So since the shortcuts you have assigned are number keys, this is just triggering the number shortcuts in Windows itself, which may activate or change dropdown boxes for example. Ah of course :) That actually taught me a good lesson to be careful trying shortcuts on a keyboard, also if your on multiple monitors and the mouse is not focused on vmix the shortcut wouldn't work. Gave me a good idea though, if I want to see whats happening with the 10 overlays it can be seen in Companion with the streamdeck.
Joined: 2/23/2023(UTC) Posts: 23 Thanks: 4 times Was thanked: 10 time(s) in 3 post(s)
Originally Posted by: David_in_Philly Great update, thanks. Is there a comprehensive list of (just) the 150 shortcuts added in V27? Code:Undo SetLayer1CropX2 SetLayer5Rectangle
SetVolumeChannelMixer1 SetLayer1CropY1 SetLayer5Width
SetVolumeChannelMixer10 SetLayer1CropY2 SetLayer5X
SetVolumeChannelMixer11 SetLayer1Height SetLayer5Y
SetVolumeChannelMixer12 SetLayer1PanX SetLayer5Zoom
SetVolumeChannelMixer13 SetLayer1PanY SetLayer6Crop
SetVolumeChannelMixer14 SetLayer1Rectangle SetLayer6CropX1
SetVolumeChannelMixer15 SetLayer1Width SetLayer6CropX2
SetVolumeChannelMixer16 SetLayer1X SetLayer6CropY1
SetVolumeChannelMixer2 SetLayer1Y SetLayer6CropY2
SetVolumeChannelMixer3 SetLayer1Zoom SetLayer6Height
SetVolumeChannelMixer4 SetLayer2Crop SetLayer6PanX
SetVolumeChannelMixer5 SetLayer2CropX1 SetLayer6PanY
SetVolumeChannelMixer6 SetLayer2CropX2 SetLayer6Rectangle
SetVolumeChannelMixer7 SetLayer2CropY1 SetLayer6Width
SetVolumeChannelMixer8 SetLayer2CropY2 SetLayer6X
SetVolumeChannelMixer9 SetLayer2Height SetLayer6Y
Effect1 SetLayer2PanX SetLayer6Zoom
Effect1Off SetLayer2PanY SetLayer7Crop
Effect1On SetLayer2Rectangle SetLayer7CropX1
Effect2 SetLayer2Width SetLayer7CropX2
Effect2Off SetLayer2X SetLayer7CropY1
Effect2On SetLayer2Y SetLayer7CropY2
Effect3 SetLayer2Zoom SetLayer7Height
Effect3Off SetLayer3Crop SetLayer7PanX
Effect3On SetLayer3CropX1 SetLayer7PanY
Effect4 SetLayer3CropX2 SetLayer7Rectangle
Effect4Off SetLayer3CropY1 SetLayer7Width
Effect4On SetLayer3CropY2 SetLayer7X
Loop SetLayer3Height SetLayer7Y
SetCCGainY SetLayer3PanX SetLayer7Zoom
SetCCGammaY SetLayer3PanY SetLayer8Crop
SetCCLiftY SetLayer3Rectangle SetLayer8CropX1
SetCrop SetLayer3Width SetLayer8CropX2
SetCropX1 SetLayer3X SetLayer8CropY1
SetCropX2 SetLayer3Y SetLayer8CropY2
SetCropY1 SetLayer3Zoom SetLayer8Height
SetCropY2 SetLayer4Crop SetLayer8PanX
SetEffect1Strength SetLayer4CropX1 SetLayer8PanY
SetEffect2Strength SetLayer4CropX2 SetLayer8Rectangle
SetEffect3Strength SetLayer4CropY1 SetLayer8Width
SetEffect4Strength SetLayer4CropY2 SetLayer8X
SetFrameDelay SetLayer4Height SetLayer8Y
SetLayer10Crop SetLayer4PanX SetLayer8Zoom
SetLayer10CropX1 SetLayer4PanY SetLayer9Crop
SetLayer10CropX2 SetLayer4Rectangle SetLayer9CropX1
SetLayer10CropY1 SetLayer4Width SetLayer9CropX2
SetLayer10CropY2 SetLayer4X SetLayer9CropY1
SetLayer10Height SetLayer4Y SetLayer9CropY2
SetLayer10PanX SetLayer4Zoom SetLayer9Height
SetLayer10PanY SetLayer5Crop SetLayer9PanX
SetLayer10Rectangle SetLayer5CropX1 SetLayer9PanY
SetLayer10Width SetLayer5CropX2 SetLayer9Rectangle
SetLayer10X SetLayer5CropY1 SetLayer9Width
SetLayer10Y SetLayer5CropY2 SetLayer9X
SetLayer10Zoom SetLayer5Height SetLayer9Y
SetLayer1Crop SetLayer5PanX SetLayer9Zoom
SetLayer1CropX1 SetLayer5PanY
8 users thanked ryxyz for this useful post.
I have to assume that vMix is going to charge a fee for ZoomISO integration? I pay $50ish a month for ZoomISO Pro, do we know if this is the case?
Joined: 3/26/2019(UTC) Posts: 16 Location: Besozzo Thanks: 3 times Was thanked: 2 time(s) in 1 post(s)
The new control of layer in the layer page is amazing, i think I will only use this section and not position but that would be really cool some shorcut or something like this for control the pivot point. Thank you
Joined: 3/23/2020(UTC) Posts: 135 Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
Congrats on the Zoom integration. I advocated for exactly this over a year ago and I am glad to see it come to fruition.
In some testing this morning a couple of observations:
1. Setting return audio to a bus other than MASTER doesn't seem to work. I tried to set the return audio to BUS A both in the input CONNECT dialog box as well as in the vMix SETTINGs under OUTPUT2.
2. Couldn't get vMix Social to connect. Threw up an error dialog. I don't have the contents but will try again later.
3. Regarding the vMix Social interface. For this to TRULY be useful, vMix Social needs THE ABILITY TO CONNECT TO A WEBINAR OR MEETING OTHER THAN THE ONE THE SPEAKERS ARE IN. The point is the be able to stage speakers/presenters in a separate meeting from the audience, capture their AV, and send a nicely packaged, switched feed back into another meeting or webinar where the audience resides. If we push the same video back into a Meeting or Webinar, there will be audio sync issues...so we need the ability to log vMix Social into another webinar or meeting that includes the audience, capture the chat and QA from that meeting and provide it via the Social app the a moderator or speakers in a different meeting. Pulling the chat/QA from the same meeting the speakers are in - with no audience - is of limited or no value.
Thanks again for implementing this. Great first effort and I am excited about all the potential here.
Greg Gibson
2 users thanked greggibson for this useful post.
Zoom pricing and vMix
Zoom have said there will be no additional fees to use this functionality in vMix for the foreseeable future, though you will still need an appropriate paid plan on Zoom's side to support things like HD resolutions etc.
vMix Social and Zoom
For privacy and security reasons you can only access the chat of meetings that vMix is a participant of. (This is a requirement of Zoom) You can connect to any meeting from vMix and don't need to bring in any of the feeds into vMix if you choose not to, but in some way vMix needs to be a participant to see the chat.
Are you saying a workaround is to run a second vMix instance logged into the Zoom session where the audience is? Social integration is really key. The number one pushback on a vMix produced Zoom Webinar is that the speakers/moderator have no direct access to the audience chat/QA and clunky work arounds have to be utilized. Greg
1 user thanked greggibson for this useful post.
Zoom allows only one meeting per computer. We have no control over this unfortunately. You would need to use a second computer to login to the webinar in vMix and use vMix Social from there, perhaps sending the graphics over NDI to the main vMix machine.
I know that is not ideal, but there isn't much we can do about it.
I am trying out the SetCrop function for a layer and no matter what values I enter for the crop in X1,Y1,X2,Y2 it seems to ignore the values and moves them to an extreme of 1920 1080 or 0 each time? Im getting the same result with a vmix shortcut and API command. SetZoom etc works perfectly fine.
Note: We are aware of a an error when using vMix Social with Zoom in the current beta, this will be fixed in the next update.
Originally Posted by: Quinton I am trying out the SetCrop function for a layer and no matter what values I enter for the crop in X1,Y1,X2,Y2 it seems to ignore the values and moves them to an extreme of 1920 1080 or 0 each time? Im getting the same result with a vmix shortcut and API command. SetZoom etc works perfectly fine. Crop values are between 0 and 1. This is so they can be used with things like dials on MIDI and Stream Deck controllers to make small adjustments. To set fixed crops, you are better off making the layers ahead of time and merging between them then adjusting through shortcuts.
Originally Posted by: admin Originally Posted by: Quinton I am trying out the SetCrop function for a layer and no matter what values I enter for the crop in X1,Y1,X2,Y2 it seems to ignore the values and moves them to an extreme of 1920 1080 or 0 each time? Im getting the same result with a vmix shortcut and API command. SetZoom etc works perfectly fine. Crop values are between 0 and 1. This is so they can be used with things like dials on MIDI and Stream Deck controllers to make small adjustments. To set fixed crops, you are better off making the layers ahead of time and merging between them then adjusting through shortcuts. OK Got you, is working fine now. So 0.01 is approx 19 on the X and 11 on the Y
Beta Discussion
