bacu89
#1 Posted : Saturday, September 23, 2023 7:10:07 PM(UTC)
bacu89
Netherlands
It would be nice to be able to assign the headphone (solo) audio bus to an output, for remote monitoring for instance.
mavik
#2 Posted : Wednesday, September 27, 2023 6:55:51 PM(UTC)
mavik
In the audio output settings you are able to set a different audio device for the monitor already. I recommend doing so.
bacu89
#3 Posted : Wednesday, September 27, 2023 7:24:07 PM(UTC)
bacu89
Netherlands
What I'm trying to achieve is that I can, for example, create an SDI output with multiviewer video AND monitor audio. This is not possible with your suggestion.
mavik
#4 Posted : Wednesday, September 27, 2023 8:03:27 PM(UTC)
mavik
In that case you can use a bus as a monitor pseudo. In the outputs you can set that bus. Create a shortcut that adds the source to the monitoring bus and you should be set.
