thesaadster
#1 Posted : Saturday, June 28, 2014 3:06:58 PM(UTC)
thesaadster
A nice feature would be some sort of way to export Lower Thirds (or any graphic) into Vmix with a plugin for After Effects with xaml support.
MrFreeze
#2 Posted : Monday, June 30, 2014 2:02:29 AM(UTC)
MrFreeze
+1
DarioGC
#3 Posted : Monday, June 30, 2014 11:34:39 AM(UTC)
DarioGC
+2
fordry
#4 Posted : Thursday, July 17, 2014 3:29:52 AM(UTC)
fordry
+3
LG
#5 Posted : Monday, July 21, 2014 6:14:38 AM(UTC)
LG
+4
melody
#6 Posted : Wednesday, July 23, 2014 6:10:31 AM(UTC)
Rank: Guest
Groups:
+5
#7 Posted : Wednesday, July 23, 2014 8:14:35 AM(UTC)
Was thanked: 4727 time(s) in 1619 post(s)
Not sure what you are looking for with this as vMix already includes a Title Designer that allows
you to import your own graphics.
http://www.vmix.com.au/help12/vMixTitleDesigner.html
If you are referring to animations in After Effects then there would be no way to convert these
as XAML animations are vector based while after effects renders to a series of images.
melody
#8 Posted : Wednesday, July 23, 2014 1:31:26 PM(UTC)
Rank: Guest
Groups:
hi admin,
understanding the all the complexity envolved, is there any way to connect vmix to adobe dynamic link to import an object from after effects, premiere or photoshop directly to vMix?
or
is there a way to import any object from adobe products based on this information below?
http://helpx.adobe.com/p...e-pro/extensibility.html
regards,
melody
www.espiritosanto.cc
Grimble
#9 Posted : Thursday, July 24, 2014 5:55:08 AM(UTC)
Grimble
It doesn't really make sense, Melody. After effects (or any NLE) must render the video out before it can be reliably played back in realtime. You can see this in after effects if you have a heavily modified sequence with tons of applied effects - they often play back within AE at very low FPS. The interface you link to is for bringing such NLE tools together, not for live playout.
For lower third graphics or anything with dynamic text, a better option is probably a flash based solution with a custom controller app. XAML is good for basic titles but doesn't allow for out animations. Or use the new key/fill inputs with CasparCG. :)
