A nice feature would be some sort of way to export Lower Thirds (or any graphic) into Vmix with a plugin for After Effects with xaml support.
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Rank: Guest
Groups: Guests
Joined: 1/13/2010(UTC) Posts: 5,308  Location: Gold Coast, Australia Was thanked: 4692 time(s) in 1611 post(s)
Not sure what you are looking for with this as vMix already includes a Title Designer that allows you to import your own graphics. http://www.vmix.com.au/help12/vMixTitleDesigner.htmlIf you are referring to animations in After Effects then there would be no way to convert these as XAML animations are vector based while after effects renders to a series of images.
Rank: Guest
Groups: Guests
hi admin, understanding the all the complexity envolved, is there any way to connect vmix to adobe dynamic link to import an object from after effects, premiere or photoshop directly to vMix? or is there a way to import any object from adobe products based on this information below? http://helpx.adobe.com/p...e-pro/extensibility.htmlregards, melody www.espiritosanto.cc
It doesn't really make sense, Melody. After effects (or any NLE) must render the video out before it can be reliably played back in realtime. You can see this in after effects if you have a heavily modified sequence with tons of applied effects - they often play back within AE at very low FPS. The interface you link to is for bringing such NLE tools together, not for live playout.
For lower third graphics or anything with dynamic text, a better option is probably a flash based solution with a custom controller app. XAML is good for basic titles but doesn't allow for out animations. Or use the new key/fill inputs with CasparCG. :)
