jameslex
#1 Posted : Wednesday, September 6, 2023 2:39:22 AM(UTC)
jameslex
The problem:
- vMix only shows a max of two audio busses regardless of how many are activated.
- Right now, the only way to control the output to busses C-F is to right click on the incorrect bus, and then you can see the other busses.
- The UI right now is confusing, as indicated in the vMix tutorial on audio busses
The solution:
- If fewer than three audio busses are activated, the UI functions like it does now ✅
- If three or more audio busses are activated, only show "M" and "BUS" on the input
- "BUS" has an arrow to indicate a small menu / popup
- The menu includes ALL busses, including master
- This allows the operator to select any (or all) busses they need at one time. (HUGE FEATURE!)
- Clicking out of the menu closes it.
Here's what it would look like.
vMix Audio Busses
thanks 2 users thanked jameslex for this useful post.
daveydouble on 9/6/2023(UTC), jet on 9/20/2023(UTC)
jet
#2 Posted : Wednesday, September 20, 2023 4:05:45 PM(UTC)
jet
Was thanked: 25 time(s) in 23 post(s)
+1
ryxyz
#3 Posted : Wednesday, September 20, 2023 10:07:38 PM(UTC)
ryxyz
Was thanked: 19 time(s) in 5 post(s)
+1
robert5521
#4 Posted : Monday, October 2, 2023 9:04:28 PM(UTC)
robert5521
Spain
Was thanked: 7 time(s) in 4 post(s)
+1
DetoxX
#5 Posted : Monday, October 2, 2023 9:21:25 PM(UTC)
DetoxX
+1
