Feature Requests
Better UI for showing Audio Busses
Joined: 1/7/2022(UTC) Posts: 34  Location: Texas Thanks: 5 times Was thanked: 5 time(s) in 4 post(s)
The problem: - vMix only shows a max of two audio busses regardless of how many are activated. - Right now, the only way to control the output to busses C-F is to right click on the incorrect bus, and then you can see the other busses. - The UI right now is confusing, as indicated in the vMix tutorial on audio bussesThe solution: - If fewer than three audio busses are activated, the UI functions like it does now ✅ - If three or more audio busses are activated, only show "M" and "BUS" on the input - "BUS" has an arrow to indicate a small menu / popup - The menu includes ALL busses, including master - This allows the operator to select any (or all) busses they need at one time. (HUGE FEATURE!) - Clicking out of the menu closes it. Here's what it would look like.
 2 users thanked jameslex for this useful post.
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 272 times Was thanked: 40 time(s) in 38 post(s)
Joined: 2/23/2023(UTC) Posts: 91  Thanks: 30 times Was thanked: 20 time(s) in 6 post(s)
Joined: 6/1/2020(UTC) Posts: 27  Location: Spain Thanks: 1 times Was thanked: 7 time(s) in 4 post(s)
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Feature Requests
