Thanks: 4 times Was thanked: 13 time(s) in 4 post(s)
 10 users thanked kricher1964 for this useful post.
Joined: 10/4/2022(UTC) Views messages in topic : 3  Was thanked: 2 time(s) in 2 post(s)
Looks amazing! Very excited about the coming support for AV1 codec, will have to upgrade the video card but it will be worth it.
 1 user thanked ericb for this useful post.
Joined: 2/23/2023(UTC) Posts: 76  Thanks: 21 times Was thanked: 11 time(s) in 4 post(s)
The updates to layers look awesome! Can't wait to try it out!
 1 user thanked ryxyz for this useful post.
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Simply amazing!! Zoom,layers new features,new web controller with live show input! Thank you very much vmix team!!
 1 user thanked nikosman88 for this useful post.
Joined: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Questions (either for the vMix team or anyone at IBC who can ask them on my behalf):
Will the Zoom input include shortcuts to start or join meetings by appending the meeting info to the shortcut?
My eyes don't work as well as they used to, and I don't like having too many programs open during production, so I've taken to starting/joining meetings using my Stream Deck and the zoommtg:// protocol. Will something similar be offered for Zoom within vMix or will everything need to be entered manually?
If the information does have to be entered manually, can it be done in advance and saved to a preset like vMix Calls or does it need to be done at the time so it doesn't start running the clock?
It looks like a great upgrade, but I'm just concerned that I'll have to have the meeting information in front of me, rather than being able to pre-set my Stream Deck to just open the Zoom meeting with the press of a button, like I'm doing now with the screen capture method.
Also, with all the new shortcuts mentioned, will there be any new activators or is it just shortcuts?
Joined: 7/27/2022(UTC) Posts: 31  Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Does it mean Zoom will come to vMix Social?
Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Simsyuk  Does this meam that you have waiting for 3 years now and haven't implemented the proposed (simple flexible) solutions ?
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Do I understand correctly that there are now 4 separate SDI outputs?
Joined: 10/31/2020(UTC) Posts: 196  Thanks: 5 times Was thanked: 44 time(s) in 43 post(s)
I want! I want! I want! :) :)
Any idea when a public beta will be available?
-- Kevin
Joined: 4/23/2017(UTC) Posts: 1,463  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
I hope after the zoom API integration the MS Teams API will follow. In a corporate world MS Teams is the goto tool. Please, please.
Joined: 2/23/2019(UTC) Posts: 137  Thanks: 18 times Was thanked: 29 time(s) in 26 post(s)
Originally Posted by: Bonbondotkom  Does it mean Zoom will come to vMix Social? Yes, Petra has shown it in their video Originally Posted by: scanscan  Do I understand correctly that there are now 4 separate SDI outputs? Yes My feature request after seeing the new features would be an extra record channel, or two, now more outputs are enabled in more places and NVidia encode limits have increased. Looking forward to seeing what all the new shortcuts are - and getting hold of a beta to try to break!
 2 users thanked RichDanby for this useful post.
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
Joined: 10/3/2021(UTC) Posts: 61  Location: Wichita Falls, TX Thanks: 6 times Was thanked: 3 time(s) in 3 post(s)
I was told beta would be out hopefully before the end of the 2023 year and hopefully the officially release by spring of 2024.
Great feature had been showed at IBC for vMix, the Zoom integration it's remarkable, as long as the new encoding features and the 4 external outputs. Wondering if in the roadmap there's still some space for audio routing updated. Currently the feature vMix is lacking the most is a proper audio mixer with full auxes and matrix array configuration, especially the possibility of integrate external output routing on the fly. Let me explain... even considering to settle all the MABCDEFG busses before starting the production, it will be great to have some sort of "external out" additioning tab where you can settle on the go a Dante audio channel or an NDI one. This feature is pretty needed, especially producer as me that handle production with multiple hardware involved, where the audio engineer makes it's own job on routing audio in the venue, for the broadcasting and for the recording at the same time. I had always thought that having the possibility to use dante physical output on the go like PCI-e cards (focusrite, yamaha, marian and so on) would give this software a complete new identity for broadcasting; a feature like tricaster/vectar had at the moment, where no matter if the input is sent to a "pre-decided" extenal hardware output can be route to a specific hardware/software output on the fly without restarting the machine...
Anyway can't wait to test this version, great job guys.
Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
Originally Posted by: simonemessina  Currently the feature vMix is lacking the most is a proper audio mixer i agree.. vMix is amazing software but the audio side is the weakest aspect IMO.. V27 has some nice additions, Zoom and AV1 are great... but hopefully somewhere in the next release cycle Martin will dedicate some more attention to audio..
Joined: 8/22/2021(UTC) Posts: 47   Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
When will the Beta Version be available? I really want to test it!
Joined: 12/12/2020(UTC) Posts: 16  Location: East Coast
Is there a list of all the new shortcuts we are getting and their descriptions? That would be nice.
