Justingonz
#1 Posted : Friday, September 8, 2023 7:50:48 AM(UTC)
Justingonz
Hey folks,
Im trying to figure out a way to keep Overlays in the preview window only. I have a custom safe area I use to set up shot's on my PTZ's during live productions and I haven't been able to figure out how to keep it from going to program. The workaround I got right now is to just turn that layer off in the output window so it doesn't get sent to my recording/stream. But it would be nice not to have to turn the overlay on and off to bring it back to preview each time.
fenki86
#2 Posted : Friday, September 8, 2023 2:59:05 PM(UTC)
fenki86
Simply click the Overlay-Button with the right mouse button and it'll only appear on preview
Justingonz
#3 Posted : Friday, September 8, 2023 3:03:00 PM(UTC)
Justingonz
Thanks for the response but that’s not what I mean. I’m looking for a way to keep overlays in preview even if I’m transitioning between inputs.
#4 Posted : Friday, September 8, 2023 4:30:24 PM(UTC)
WHile the right click would do it the problem remains when you transition preview to output the overlay will follow .
An option might be to use triggers . assuming the custom safe area is only usefull for camera inputs put them as a layer (not overlay) in these inputs and trigger them to turn that layer on/off on transition ( benefit will be the save area will also be visible in the small input windows )
Alternativly similar to above trigger to put overlayx on preview and turn layerx off (works with cut not so much with others) .
To avoid possible (short) visibility to actual output during certain transitions , turn the layer of in output settings
Justingonz
#5 Posted : Saturday, September 9, 2023 3:40:35 AM(UTC)
Justingonz
Thanks doggy, this does seem to work for the most part. It just seems odd there's no way to turn off the auto-transition of overlays. If that were possible that would immediately solve my problem.
