Henny
#1 Posted : Friday, July 18, 2014 6:19:39 AM(UTC)
Henny
Hi all
I have an install comming up where I need 4 ptz cameras , one option I'm considering is going for 4 x hd sdi heads and a decklink quad . But could it be done uesing only ip? Would I get any issues with the 4 ip cameras going out if sync with each other , I will be filming meetings and the audio will be comming off an existing microphone system ,
What cameras would people recommend ?
Cheers
Ian
LG
#2 Posted : Monday, July 21, 2014 5:55:49 AM(UTC)
LG
beside the problem you discribe you now that there is a longer delay in al IP cams compared to the audio you record!
also ipcams generally dont give a nice frame rate!
