Joined: 5/14/2013(UTC) Posts: 152  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
Hi all
I have an install comming up where I need 4 ptz cameras , one option I'm considering is going for 4 x hd sdi heads and a decklink quad . But could it be done uesing only ip? Would I get any issues with the 4 ip cameras going out if sync with each other , I will be filming meetings and the audio will be comming off an existing microphone system ,
What cameras would people recommend ?
Cheers
Ian
beside the problem you discribe you now that there is a longer delay in al IP cams compared to the audio you record! also ipcams generally dont give a nice frame rate!
