Is it possible to decide the duration of the recording? I would like the files to all be exactly 15 minutes long
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: MaxItalia  Is it possible to decide the duration of the recording? I would like the files to all be exactly 15 minutes long Check the recording option "New file every X minutes"
and if I need it from 14?
Originally Posted by: MaxItalia  and if I need it from 14? Really funny ! Then you will need to write a script checking the current recording duration time from the vMix API XML and let it stop the recording after 840 seconds of recording time but tthat wont be you wanting of the exact 15 minutes ;-) Check the "scripting for dummies" post on how to retrieve info from the API XML and activae functions etc
