coskel22
#1 Posted : Saturday, July 19, 2014 12:00:00 PM(UTC)
coskel22
Hi all -
Using VMix 12.9 on an HP Z800 with 24Gb of RAM and dual core Intel processors.
Encoding is an Osprey Viewcast 260e
I am choosing MPEG as my Save As when recording a file to harddrive at the default settings of 25 Mb, which results in an average filesize of 5-17Gbs when recording 1-2 hours of talking heads in a meeting.
I tried the TS setting but it was actually worse.
My video card on the server is an NVidia GeForce Quadro 2Gb with DVI + 2 display ports. When I use the display port to go to a DVD burner the recorded DVD is much better than the file recorded to HDD.
I am using the SD version of vMix, and my inputs and switcher are all SD composite analog.
So a clean analog picture is what I'm expecting, but I get a very blurry video and the graphics are also out of focus.
They are crisp on the live stream, so its only the file recorded to HDD that is the issue.
What do I need to do to get a clean SD archive file on the HDD?
#2 Posted : Saturday, July 19, 2014 12:33:11 PM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
Can you provide a copy of the log file?
Also a still from the video would be helpful.
I just ran a test of an SD recording at both 8 Mbps and 25 Mbps with good results.
coskel22
#3 Posted : Friday, July 25, 2014 9:29:49 AM(UTC)
coskel22
7/22/2014 8:33:47 AM, Version: 12.0.0.129 x64
7/22/2014 8:33:47 AM, Size: 720x486
7/22/2014 8:33:47 AM, System: NTSC 59.94i or 29.97p
7/22/2014 8:33:47 AM, Codec: Microsoft MPEG-2 Encoder
7/22/2014 8:33:47 AM, Format: UYVY 16 1498831189
7/22/2014 8:33:47 AM, AudioDevice: vMix Audio
7/22/2014 8:33:47 AM, AudioFormat: 48000 Hz 16 Bit 2 Channels
7/22/2014 8:33:47 AM, AudioDelay: 0
7/22/2014 8:33:47 AM, RestartInterval: 0
7/22/2014 8:33:47 AM, BitRate: 25
7/22/2014 9:32:06 AM, StartRecording
7/22/2014 10:57:04 AM, StopRecording
7/22/2014 10:57:04 AM, Duration: 01:24:58
7/22/2014 10:57:04 AM, Frames: 152798
7/22/2014 10:57:04 AM, DroppedFrames: 0
7/22/2014 10:57:04 AM, DueToSourceFrameRate: 0
7/22/2014 10:57:04 AM, DueToHardDiskOrCPU: 0
7/22/2014 10:57:04 AM, DroppedSamples: 0
7/22/2014 10:57:04 AM, MissedSamples: 0
7/22/2014 10:57:04 AM, SyncedSamples: 0
7/22/2014 10:57:04 AM, AudioOffset: 0
7/22/2014 10:57:04 AM, AudioDelay: 0
7/22/2014 10:57:04 AM, AudioEngine
7/22/2014 10:57:04 AM, Running: True
7/22/2014 10:57:04 AM, SampleRate: 48000hz 16 Bit
7/22/2014 10:57:04 AM, MixingErrors: 0
7/22/2014 10:57:04 AM, Streams
7/22/2014 10:57:04 AM, Stream0
7/22/2014 10:57:04 AM, Samples: 0
7/22/2014 10:57:04 AM, Dropped: 0
7/22/2014 10:57:04 AM, Latency: 0
7/22/2014 10:57:04 AM, Stream1
7/22/2014 10:57:04 AM, Samples: 455693
7/22/2014 10:57:04 AM, Dropped: 2
7/22/2014 10:57:04 AM, Latency: 1
7/22/2014 10:57:04 AM, AudioInputs
7/22/2014 10:57:04 AM, Osprey-260e Video Device 1
7/22/2014 10:57:04 AM, Latency: 70/67
7/22/2014 10:57:04 AM, Resampled: 388 ms
coskel22
#4 Posted : Friday, July 25, 2014 9:31:16 AM(UTC)
coskel22
I can send an image privately I can't upload it to a public forum due to a non-disclosure agreement.
coskel22
#5 Posted : Tuesday, July 29, 2014 3:58:42 PM(UTC)
coskel22
any suggestions based on the log file?
Here is a screenshot from an event yesterday:
