Feature Requests
Allow more dynamic variables
Joined: 3/7/2022(UTC) Posts: 72  Location: Munich Was thanked: 33 time(s) in 17 post(s)
vMix currently allows just 4 dynamic variables and 4 dynamic inputs. Especially the dynamic variables are needed for passing information to VB.Net extension scripts and scripts having to compete against just 4 hard-coded variables is nasty. Please allow at least a few more of those dynamic variables so there is less contention on them.
 1 user thanked engelschall for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,522  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: engelschall  vMix currently allows just 4 dynamic variables and 4 dynamic inputs. Especially the dynamic variables are needed for passing information to VB.Net extension scripts and scripts having to compete against just 4 hard-coded variables is nasty. Please allow at least a few more of those dynamic variables so there is less contention on them. Have you considered using multiple "variables" within one Dynamic variable (xml, csv style)?
You mean placing a string like "<arg1>value1</arg1><arg2>value2</arg2>" into a dynamic variable in order to be able to pass multiple arguments to a script? Yes, of course. But this doesn't solve the problem if you are using N scripts which require argument(s) from a remote control that everything has to flow through just 4 variables in total. Additionally, if you want to keep state in a variable the situation is even more worse because you loose an entire variable per state forever. My workaround in those state situations is to place the state into a "title" input (which is never shown but just keeps the state).
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Yes PLEASE! at least as many as there are vmix call inputs or better yet as many as mix type inputs which in v26 seems to be 16 !
Originally Posted by: SuperBill  Yes PLEASE! at least as many as there are vmix call inputs or better yet as many as mix type inputs which in v26 seems to be 16 !
I fully agree. There definitely needs to be more dynamic inputs and 16 as far as I can tell, would be an ideal number. Right now, I've easily used up all 4 dynamic inputs on a rather simple layout. Basically, with dynamic inputs, you can cue up multiple inputs such as songs, videos, active inputs, and overlays and maintain independent control over all of them. But 4 is the current limit, and it's just not enough. I cannot think of a scenario right now where I would need more than 16. I highly doubt the need for higher than 16 will ever be there. But certainly I can reach 8 or 10 within any issues. So I think 16 is actually a very good number.
Joined: 7/27/2022(UTC) Posts: 31  Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: engelschall  vMix currently allows just 4 dynamic variables and 4 dynamic inputs. Especially the dynamic variables are needed for passing information to VB.Net extension scripts and scripts having to compete against just 4 hard-coded variables is nasty. Please allow at least a few more of those dynamic variables so there is less contention on them. +1
Joined: 2/8/2023(UTC) Posts: 24  Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Joined: 8/26/2020(UTC) Posts: 17  Location: Velsen / The Netherlands Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Feature Requests
