Maku
#1 Posted : Wednesday, July 26, 2023 5:56:29 AM(UTC)
Maku
Hello everyone. In an excel file I have two rows of texts. In first row, I used local language font and the second row I used superscript to show degree Celsius. Both the texts are displayed correctly in cell but different in formula bar. I want vmix to display the data shown in the cell not the formula bar. Thanks.
fenki86
#2 Posted : Wednesday, July 26, 2023 4:55:17 PM(UTC)
fenki86
Rank:: Advanced Member
vMix always reads the raw data without formatting. You'd have to use the correct symbol for degree and not a 0 which has been formatted. You'll find the degree-symbol if you click on the Tab Insert and the symbol.
Maku
#3 Posted : Wednesday, July 26, 2023 7:20:07 PM(UTC)
Maku
Thank you for your reply. What about the font? Any solution please.
fenki86
#4 Posted : Wednesday, July 26, 2023 7:44:56 PM(UTC)
fenki86
the font wouldn't matter - but you can try Arial for example. Or just hold down your ALT-key on the Keyboard and while holding the button down press 0176 on the numpad. If you release the ALT-Button it'll insert the degree-symbol.
#5 Posted : Wednesday, July 26, 2023 8:10:49 PM(UTC)
can always just use the value in your datasource (omit the °C) and format the ddatasource connection in the title
Screenshot 2023-07-26 120833.jpg (32kb) downloaded 1 time(s).
Maku
#6 Posted : Wednesday, July 26, 2023 8:28:44 PM(UTC)
Maku
Thank you. I mean the font/language I used in the first row. I used local language font that shows correctly in the cell but not in the raw(formula bar). vMix display the formula bar value. please!
Maku
#7 Posted : Wednesday, July 26, 2023 8:34:46 PM(UTC)
Maku
Thank you, I got one answer. Second one is the font/language I used in the first row. I used local language font that shows correctly in the cell but not in the raw(formula bar). vMix display the formula bar value. please!
Maku
#8 Posted : Wednesday, July 26, 2023 8:39:56 PM(UTC)
Maku
Thank you doggy. First row problem please?
#9 Posted : Wednesday, July 26, 2023 9:50:22 PM(UTC)
Have you tried using same font in vMix (title) itself ?
fenki86
#10 Posted : Wednesday, July 26, 2023 11:38:04 PM(UTC)
fenki86
as doggy mentioned you'd have to use this font in vmix as well. If it's on another computer you might have to install the font there first.
Maku
#11 Posted : Friday, July 28, 2023 2:45:14 PM(UTC)
Maku
Yes. I used in GT title there It worked perfectly.
