Hello everyone. In an excel file I have two rows of texts. In first row, I used local language font and the second row I used superscript to show degree Celsius. Both the texts are displayed correctly in cell but different in formula bar. I want vmix to display the data shown in the cell not the formula bar. Thanks.  22.jpg (91kb) downloaded 1 time(s).
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
vMix always reads the raw data without formatting. You'd have to use the correct symbol for degree and not a 0 which has been formatted. You'll find the degree-symbol if you click on the Tab Insert and the symbol.
Originally Posted by: fenki86  vMix always reads the raw data without formatting. You'd have to use the correct symbol for degree and not a 0 which has been formatted. You'll find the degree-symbol if you click on the Tab Insert and the symbol. Thank you for your reply. What about the font? Any solution please.
the font wouldn't matter - but you can try Arial for example. Or just hold down your ALT-key on the Keyboard and while holding the button down press 0176 on the numpad. If you release the ALT-Button it'll insert the degree-symbol.
can always just use the value in your datasource (omit the °C) and format the ddatasource connection in the title  Screenshot 2023-07-26 120833.jpg (32kb) downloaded 1 time(s).
Originally Posted by: fenki86  the font wouldn't matter - but you can try Arial for example. Or just hold down your ALT-key on the Keyboard and while holding the button down press 0176 on the numpad. If you release the ALT-Button it'll insert the degree-symbol. Thank you. I mean the font/language I used in the first row. I used local language font that shows correctly in the cell but not in the raw(formula bar). vMix display the formula bar value. please!
Originally Posted by: Maku  Originally Posted by: fenki86  the font wouldn't matter - but you can try Arial for example. Or just hold down your ALT-key on the Keyboard and while holding the button down press 0176 on the numpad. If you release the ALT-Button it'll insert the degree-symbol. Thank you, I got one answer. Second one is the font/language I used in the first row. I used local language font that shows correctly in the cell but not in the raw(formula bar). vMix display the formula bar value. please!
Originally Posted by: doggy  can always just use the value in your datasource (omit the °C) and format the ddatasource connection in the title  Screenshot 2023-07-26 120833.jpg (32kb) downloaded 1 time(s). Thank you doggy. First row problem please?
Have you tried using same font in vMix (title) itself ?
as doggy mentioned you'd have to use this font in vmix as well. If it's on another computer you might have to install the font there first.
Have you tried using same font in vMix (title) itself ? Yes. I used in GT title there It worked perfectly.
