GT
Transition in/out
Hello I need to set some transitions in and out on a graphic that need to show a lineup of a hockey team. As you see in the file attached that i did quickly just to explain the effect, i need a background which stays in with a transition in, and then I need some elements go in and out. Of course every white rectangle when it goes in and out have different informations comiing from a data source according to the player that need to be shown. I tried to set the in and out of the layers as pages but as soon as I want to show page 2, page 1 stays in even if i set page 1 as hidden (my mistake or is it not possible to set as hidden a page which is already in?). I also tried to set the transitions out and in for every element in order to have everything automatic, but I was able to set transitions out just for the whole graphic. Any ideas? Thanks clip sample ----> test clip
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: barkley  Hello I need to set some transitions in and out on a graphic that need to show a lineup of a hockey team. As you see in the file attached that i did quickly just to explain the effect, i need a background which stays in with a transition in, and then I need some elements go in and out. Of course every white rectangle when it goes in and out have different informations comiing from a data source according to the player that need to be shown. I tried to set the in and out of the layers as pages but as soon as I want to show page 2, page 1 stays in even if i set page 1 as hidden (my mistake or is it not possible to set as hidden a page which is already in?). I also tried to set the transitions out and in for every element in order to have everything automatic, but I was able to set transitions out just for the whole graphic. Any ideas? Thanks clip sample ----> test clip
Originally Posted by: doggy  Originally Posted by: barkley  Hello I need to set some transitions in and out on a graphic that need to show a lineup of a hockey team. As you see in the file attached that i did quickly just to explain the effect, i need a background which stays in with a transition in, and then I need some elements go in and out. Of course every white rectangle when it goes in and out have different informations comiing from a data source according to the player that need to be shown. I tried to set the in and out of the layers as pages but as soon as I want to show page 2, page 1 stays in even if i set page 1 as hidden (my mistake or is it not possible to set as hidden a page which is already in?). I also tried to set the transitions out and in for every element in order to have everything automatic, but I was able to set transitions out just for the whole graphic. Any ideas? Thanks clip sample ----> test clip yes I saw this one, but I don't understand why my page keep staying in even if on page 2, I put page 1 as hidden.. is it just my mistake or is it not possible to have pages in and out as I want?
There must be a mistake somewhere on your end , you havent given much info on any other animations that might be there that could interfere
 Screenshot 2023-07-26 101127.jpg (137kb) downloaded 3 time(s).
 test animation.png (471kb) downloaded 8 time(s).Originally Posted by: doggy   Screenshot 2023-07-26 101127.jpg (137kb) downloaded 3 time(s). i have this
GT
Transition in/out
