Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
I would like to propose an addition to vMix transitions: ZoomFade. Transition in: centered zoom out from e.g. 2x to 1x while fading in Transition out: fade out while zooming Use scenario: a smooth global transition for one or multiple content layers positioned at near the edges of the image area. 2x zoom ratio is proposed on a basis of center area being usually free of overlay content. Example principle:  vmix_zoom_fade.png (22kb) downloaded 0 time(s).
Originally Posted by: jip  I would like to propose an addition to vMix transitions: ZoomFade.
Example principle:
A few lines of code in vMix scripting (using ZetZoom and SetAlpha functions) can do that for you (until feature request is implemented of course)
That's true, but for I wouldn't use modified input zoom and alpha properties constantly to achieve "only" a transition-type outcome. So I'll count the comment as +1 :)
