MaxItalia
#1 Posted : Sunday, July 9, 2023 1:36:17 AM(UTC)
MaxItalia
Italy
Hi, I'm looking for a way to create a countdown counter that can set in different ways such as 100 seconds or 300 seconds.
On the video I have to see the 3 digits or (200) or (300) and not the classic clock to understand ... can anyone help me?
countdown 200-0 ecc
#2 Posted : Sunday, July 9, 2023 2:42:44 AM(UTC)
countdown 200-0 ecc
probably better to use a script and format the display to your liking of the time using the DateTime.Now() or the stopwatch options to calculate
in vb.net
MaxItalia
#3 Posted : Sunday, July 9, 2023 3:06:27 AM(UTC)
MaxItalia
Italy
in vb.net
yes, but i don't know how to do it
#4 Posted : Sunday, July 9, 2023 10:23:59 AM(UTC)
see https://forums.vmix.com/...g-for-Dummies#post109323
MaxItalia
#5 Posted : Sunday, July 9, 2023 11:30:32 PM(UTC)
MaxItalia
Italy
you are very kind! i tried to insert the script but i can't get it to work, i don't understand how to do it. If you can explain it would help me. Thank you
nikosman88
#6 Posted : Monday, July 10, 2023 11:22:12 PM(UTC)
nikosman88
Greece
Hello. What difficult you have in order to run the script?
You must change the line
API.Function("SetText",Input:="9",SelectedName:="Headline.Text",Value:=ctime) in order to match to your needs.
Do you have in vmix a title input in input 9 position that have the field "Headline.Text"?
If no, you must change this in what you have. Also the line dim total as integer = 250 'Total # of seconds to count down means the time you need. If you need 300 seconds you will change the = 250 to = 300
And finally you can make a shortcut to run this script whenever you need it
