Hi, I'm looking for a way to create a countdown counter that can set in different ways such as 100 seconds or 300 seconds. On the video I have to see the 3 digits or (200) or (300) and not the classic clock to understand ... can anyone help me?
countdown 200-0 ecc
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: MaxItalia  Hi, I'm looking for a way to create a countdown counter that can set in different ways such as 100 seconds or 300 seconds. On the video I have to see the 3 digits or (200) or (300) and not the classic clock to understand ... can anyone help me?
countdown 200-0 ecc probably better to use a script and format the display to your liking of the time using the DateTime.Now() or the stopwatch options to calculate in vb.net
Originally Posted by: doggy  probably better to use a script and format the display to your liking of the time using the DateTime.Now() or the stopwatch options to calculate in vb.net
yes, but i don't know how to do it
Originally Posted by: doggy  you are very kind! i tried to insert the script but i can't get it to work, i don't understand how to do it. If you can explain it would help me. Thank you
Originally Posted by: MaxItalia  Originally Posted by: doggy  you are very kind! i tried to insert the script but i can't get it to work, i don't understand how to do it. If you can explain it would help me. Thank you Hello. What difficult you have in order to run the script? You must change the line API.Function("SetText",Input:="9",SelectedName:="Headline.Text",Value:=ctime) in order to match to your needs. Do you have in vmix a title input in input 9 position that have the field "Headline.Text"? If no, you must change this in what you have. Also the line dim total as integer = 250 'Total # of seconds to count down means the time you need. If you need 300 seconds you will change the = 250 to = 300 And finally you can make a shortcut to run this script whenever you need it
